3 speed shift levers
  • Steering: 3 speed shift levers
    1962 Lark wagon. I have installed a T5 transmission in the wagon and am no longer using the column shifter. I removed the split pin from the shifter handle but cannot release it from the steering column. Is there something else that holds it in place or do I just have to apply greater pressure?
    Thanks
    Warren
    Put it in Neutral, push the Lever DOWN (Toward the dash, and base of the Column) and give it a GOOD Pull!
    That SHOULD lift the flat Cog UP, out of the Shift Tube and leave only the Rubber Grommet holding it.
      There is a tooth on the lever that is probably hanging up. when it is in neutral that tooth is engaged in the 2-3 shift tube. Pull the lever toward the steering wheel then pull out at the same time.
      Pushing it will do nothing to free it up.
      Bez Auto Alchemy
        Got it out with a little effort. That rubber grommet has great holding power.
        Thanks
        Warren
          The level of experience and expertise on this forum never ceases to amaze me! Thank Goodness for our archives here too. If/when someone else has the same question, this thread will provide the answer, even if 50 years from now.
