Hood insulation installation
  • Body / Glass: Hood insulation installation
    Hi all doing research on the under hood insulation install for my 64 Hawk.
    Does it really just use spray adhesive? I looked up
    posts and the below was mentioned:
    3M Super Trim Adhesive Yellow - part # 08090
    Will that really stand up to the heat? Is there a more modern solution for installation?
    Thanks!
    1964 Studebaker GT Hawk
    1970 Jaguar E-Type 2+2
    2003 Ferrari 575 Maranello (3 Pedal)
    2007 Jaguar XK Convertible
    2011 Jaguar XJL 5.0 SC
    I used that same adhesive, worked great. It's messy to work with so make sure the engine and fenders are well covered. It's been 3 years and no sag, seems to be holding up well.
      I don't mean to offer advise where it is not asked for, but "dsd" is relatively new to the forum. Remember that the hood insulation on GT Hawks is offset to the passenger side of the hood. I can offer this for sure on the 1963, but, I believe it also applies to the 1964.
      Perry
      \'50 Business Champion
      \'50 Starlight Champion
      \'60 Lark Convertible,
      \'63 GT R1,
      \'67 Triumph TR4A
        Thanks, all information is welcome. The car has the foam (probably generic or repro) just not attached. The foam looks bigger than the partial, but I haven’t done a test fitting. We were just concerned that spray adhesive was really the answer. We are more familiar with European cars and there are usually clips or shields on the engine.
          Applying it is a LOT easier if you take the hood off the car and turn it upside down.
          60V-L6 - 60 Lark convertible
            Follow the 3M instructions exactly. Taking shortcuts will lead to partial failure.
            Skip Lackie
              My 55 Commander Sedan has that same offset location pattern under the hood. I was wondering about that. Could that have been a heat shield? Why off to the side? It had a single exhaust, maybe that was enough to cause the offset.
                I believe this was discussed before. Wasn't it offset to keep it away from the battery?
                  Yes, it is.
                    I wonder if it’s still needed with modern batteries? I’ll have mine offset, just curious.
                      Yes, the terminals are still there and you always want to keep heat away from the battery, not insulate the engine heat to it.
                        So then, what purpose does it serve, when installed on the passenger side? I'm sure I've heard this before, but now, it's not coming to me!
                        Mark
                        S2Deluxe = (5H - C3).
                          Mark
                          I believe that the main purpose is sound deadening. Of course there is also some insulation to save the hood paint.
                            This was Studes' explanation back in '55.......
                            "Burning Bridges...Lost Forevermore"......
                              Cool information from 1955! looks like it was partly to save money. It doesn't mention the heat over the battery, but that theory makes sense also.
