Does anyone have a photo of the location for the two heater hose tees, manual photo not clear to me
53 V8 Heater hose tee location
Tags: None
BOTH the Defrost Input AND the Under Seat Core Input from the TOP Arm of the Water Manifold on a V8 or a Cyl. Head on a 6 (Hottest, returning water to the Rad.) MUST FIRST go to the Climatizer Temp. Control Valve.
The other Two are the return to the Lower Water Manifold Fitting.
To more directly answer that, the above Manual Picture shows the Hot Input going to the Passenger Side Bent Tube on the Control Valve.StudeRich
My engine had a hose running from the top arm of the water manifold to the passenger side of the water valve, wrong I guess? Which hose is which from the heater core, passenger side (outer) is? Driver’s (inner)? To clarify, each hose from the core go to a tee. The other side of each tee has a 5/8 to where and the small hose of each tee to where?
