New gas tank install 53 Starliner
  • #16
    Got it!! I put a vice grip on the tank mount lip and the body mount and drew the tank up just a smidge to expose a couple threads to get the nut on under the spring. Thanks Stephen Allen for the tank, perfect fit!!
    • #17
      Great ending and information for all of us when wrestling with gas tank issues. Now get her going and start.
      Bob Miles
      • #18
        Filler tube install next. Shop manual says put tube in tank first. There’s no way you can put this tank in with the tube attached.
        • #19
          Tim texted me that he was able to get the nut on by using a
          vice grip to compress the spring.
          End of saga.
          • #20
            Bob misunderstood me, it was as I explained in post #16
            • #21
              How tight should the castle nut be on the spring? Just enough to clear the hole in the bolt for the cotter pin? Thanks as always
              • #22
                Just enough so the cotter pin lines up with the hole, when passed through one of the castle nut slots. That leaves it just a tad below the trunk floor, or if felt pads were used on top, they might even be kissing the trunk floor. Don't need/want it too snug against the trunk floor.
                • #23
                  Another way to measure would be to insure the rear lip of the tank sits parallel along the rearmost frame crossover. The driver's side mount is fixed, so just make sure the passenger side mount is adjusted so the tank sits level, left to right. Again, that will be when the cable nut is tightened just enough for the cottter pin hole to line up.
                  • #24
                    Thanks Joe
