I want to check the fluid in the master cylinder on my 62 GT and cannot turn the cap even with lots of pressure on the handled of my ratchet. Should I just put more pressure. I am concerned about destroying something. It has been over 4 years since I had the brakes redone. Thanks for any suggestions you can give.
Master cylinder lid will not turn on 62 GT
Those "?zink?" caps can be pretty tight sometimes; corrosion is often involved.
In addition to what Mike said above, consider using some penetrating fluid & giving it time to work.
Maybe even doing some gentle tapping all the way around the outer edge of the cap above the threads.
- 1 like
It will come off but I question that you don’t check this a couple times a yearsigpic
- 1 like
Dissimilar metals. Electrolytic corrosion.
Newer caps are plastic, so this condition disappears.
If you want to keep your original cap, lightly wire brush the cap threads and then buff the cap threads like you are polishing it to look good.
Then use a light film of non-metallic grease (not anti seize).HTIH (Hope The Info Helps)
- 1 like
