Park Brake Cable
  • Brakes: Park Brake Cable
    Hello,
    Installing the Park brake on my '61 Hawk, at the end of the cable cover it has a brass section that is dished for a holding bracket, problem is I don't really know what this looks like.
    My car is RH drive, so could be a bit different from standard, there is also some unexplained holes in the floor directly above it, hopefully someone can shed some light on this,
    thanks in advance, Click image for larger version
ID:	1813578Click image for larger version
    Thightens to floor with a short special J-bolt
    Milt
    1961 Hawk 4-speed
    1967 Avanti
    1961 Lark 2 door
    1988 Avanti Convertible
    Member of SDC since 1973
      In a left hand drive car the cable passes almost directly under the accelerator pedal. I see in your first photo two small holes in the floor.
      This would be the location of the "j" bolt, which, if memory serves, has a 1/4" inside diameter. But don't trust my memory.
      If a "j" bolt isn't readily available, just get a cable clamp and cut off one side of the threads.
      The "j"bolt goes up from under the floor with the short leg of the j just resting in the second hole. A nut above the floor secures the cable tightly underneath.
      '33 Rockne 10,
      '51 Commander Starlight,
      '56 Sky Hawk
        Great, thanks for the info
          This is a left hand drive Hawk, but you can see there is a U/J bolt that holds it. It bolts through the floor and has a nut on just one side of the "U" or "J".
            That great Ben, good pic,
            thanks
              thanks
              No problem. This question has been asked before. Back then my car was on the rack (changing transmission) so it was easy to take a pic, and it is on this machine, so redily available.
                Hi Cus, the E Brake cable mount shown in the photo is no big deal if it has gone missing you can make one it's just a piece of thin flat that's held in place by the J bolt, probably there to stop creasing the floor if over tightened. Cheers Harryhawk
                  I use the u-bolt and nuts from a braided cable clamp. Works the same.
                  Claude Chmielewski
                  Studeski
                  http://www.studeski.com
                  Fillmore, Wisconsin
                  47 M-16 Truck
                  53 Commander Regal HT
                  53 2R5
                  60 Lark VIII Convertible
                  60 5E7 Champ pickup
                  62 5E7 Champ no box
                  62 GT Hawk 4 speed
                  63 Lark VI parts car
                  63 GT Hawk R2 4 speed
                  64 Commander Wagonaire
                  64 Daytona Convertible
                  50 Champion Regal (parts car)
                  36 Dictator
                  36 Dictator in pieces
                    Me too. The U bolt can be fastened more securely with 2 nuts. Be sure to use that little reinforcing plate; if you do not have one, one can easily be made.
