This is my story. I have a 51 champion that had a bad block. I am having it rebuilt at a shop and I brought them a block out of a studebaker truck. Both engines are straight sixes. I am being told that using my bell housing the starter will be on the opposite side and will cover the oil fill hole in the block. How should I proceed? Do I need to find a truck bell housing ? I am being told the my passenger bell housing lines up just the starter issue. Can anyone shed some light on this for me
Studebaker truck block to a passenger car
Just switch them by moving the Oil Fill Pipe to where the Core Plug is.
Pay special attention to the Oil Pan and Oil pump locations, also the rear "Mounting Plate" between the Clutch housing and the Block that "Some" 169 Engines had.
There were several Car to Truck changes, so the only way to get them all Right is to have BOTH the Car Chassis Parts Catalog and the Truck Parts Catalog for the years involved and compare part numbers for 169 Engine and Clutch Parts.
It WILL matter which Year the Truck is!
For instance: 1955 to 1958 Cars and Trucks used the "185" c.i.d. small Six.
You cannot use a Truck Clutch Housing; different Transmission Mounting and Engine Mount locations.StudeRich
Originally posted by Jwboff View PostThis is my story. I have a 51 champion that had a bad block. I am having it rebuilt at a shop and I brought them a block out of a studebaker truck.
jack vines
This is STILL your only foolproof method:
Quote Post # 3: "There were several Car to Truck changes, so the only way to get them all Right is to have BOTH the Car Chassis Parts Catalog and the Truck Parts Catalog for the years involved and compare part numbers for 169 Engine and Clutch Parts."StudeRich
