Different tanks?
  • Fuel System: Different tanks?
    I wonder if there's different gas tanks depending on single, 6 cyl & 2 to 1 V8's, or dual exhaust, V8, systems?
    (My -55 Champion gas tank only has the space for exhaust pipe on one side but I've seen pictures from under other Studebakers that have the space on both sides...)
    Josephine
    -55
    Champion V8
    4d sedan
    This is what Josephine's tank looks like:
    (I wonder if it's the same on V8 sedans of later date?)
    Josephine
    -55
    Champion V8
    4d sedan
      That is what the tanks all look like in that era on the sedans. Normally the right pipe would run in the the valley between the tank and the spare tire well. The left pipe snakes way to the left of the tank. Both of the pipes end up at the bumper just to the inside of the tail lights. My 56 President is away in the barn for the winter but if you are stuck I will try to visit it and take a photo.
        Alright Ross, so there's no "in-bump/dent" or tunnel on the left side on a -56 sedan, but I still wonder if for example V8 Lark has the same..?
        Josephine
        -55
        Champion V8
        4d sedan
          Larks all have rectangular tanks with no indents for pipes. Those cars did not have spare tire wells and the filler was at the back so there were less obstacles for the pipes.
            From what I've seen the tanks on the C/K model cars are the same size and shape. There are differences in where and how the fuel pickup line exits the tank though. On the V8 cars, (both a bit later with stock dual exhaust) the tank is centered between the springs. On our '53 coupe, originally with a 6 cylinder, the tank was mounted further to the left side. When we swapped in a V8 and dual exhaust we moved the tank to center between the springs.
            This is my '62 K
              Okidoki, thanx!
              I just googled a picture of a Lark,
              & so I reckon there was never a tank with made space for exhaust pipes on both sides, but I still wonder for example why 57-58 Packard sedans wouldn't have it.
              Josephine
              -55
              Champion V8
              4d sedan
