Lube recommendation
  • Steering: Lube recommendation
    What have you used in a non-power steering box for lubrication? I'd like to top off the box on my '58 Champion. Also, there appears to be a seal failure where the steering arm is attached since it looks like there's been drippage over the years. Is it a bear to get that arm off to tackle the seal? Obviously I'd mark both sides to reinstall on the same spot, and after 60+ years I don't begrudge a worn out seal. :-) Heck, I'm 67 and could use a few of my own seals replaced!
    Is it a Ross box, or a Saginaw box? They use different lube. Ross boxes use special semi-fluid grease, because they have a sliding contact between the cam lever pin and the cam. Saginaw boxes are recirculating ball, and 90W gear lube without the EP rating is used. I have used moly-based CV joint grease in Ross boxes, and it seems to work. An adequate supply of "incorrect" lubricant may be better than an insufficient supply of the right stuff. The Saginaw box, viewed from the top, looks roughly cylindrical, with a pipe plug near the top end. The Ross box, when viewed from the fender well side, has a "sector-shaped" cover plate that looks sort of like a baseball field. I think you Champion should have a Saginaw.
      I'm using 90wt GL1 in my Ross SL-54 box (the big ross box) in my '62. Works fine and I believe that is what the manual called for too.
        I've been using NGLI #00 semi fluid grease in leaky steering boxes with good results. Bud
          Later Ross boxes wth the roller pin sector shaft call for 90 wt. It's the earlier type with the solid pin that use the semi-fluid grease.
          Bez Auto Alchemy
            Which box is in an Avanti?
              Mine is a Ross, (dress for less) box. :-) I've also used CV axle grease in others with no ill effects that I could tell. Thanks much, Guys!
                Avantis have the roller pin, and 90 wt is recommended. If the cross shaft bearings are sloppy, then the grease seal will leak. If you drive it long distances the heat from the manifold will cook the seal, and it will leak. The Avanti is also one of the only Stude boxes with a top seal. often hard as a rock too.
                Bez Auto Alchemy
                  So the semi fluid oil is not to be used?............Jon Myer sells it in a calking type of tube. ('64 Avanti)
                    Top off for dummies time.............. what is the correct way to determine if the box needs additional oil?
                      I was advised on this forum to use Lucas Chain Lube in my '59 Lark, Standard Steering and it works great.
                        I use John Deere Corn Head Grease.
                          If you remove the fill plug and there is room to add more , you top it up. If it's been a while since you checked, or it's wet or greasy around the sector shaft...it does. This is one area nobody ever thinks about when lubing stuff.
                            No matter which Lube it calls for, if the Seal is badly leaking as you say, NO "Oil" is going to work.
                            It will take John Deere Corn Head Semi-Fluid Grease or equivalent to KEEP it in.
                              What size 3/8 drive square socket can I use to remove the fill plug?
