Radio support arm, 1955 Commander
  • Merwin
    Mystery solved, thanks to Radio Roy. My problem was that the radio I had was not the correct radio for my unique car. The 55 sedan with wrap around windshield used a different speaker chassis. Basically the radio is comprised of three chassis (tuner chassis, power supply and audio amplifier chassis and the speaker chassis).The speaker chassis contained the mounting brackets that attach to the dashboard rail. These mounting brackets were at a unique angle and length as well as the speaker chassis may have been at a slightly different angle. Bottom line, I found a radio that fit my car, it was a 6 tube, manual tune radio. I used only the speaker chassis and used my original 8 tube, push button radio chassis.
  • RadioRoy
    If you are asking about the zig-zag arms that attach the rear of the tuner to the bottom of the speaker/amplifier chassis, they are clearly shown in this eBay auction picture, auction number 372804354439
    Those zig-zag arms are the same for all 53-55 Studebaker radios.
  • RadioRoy
    There are two sheet metal-type screws that come up from the bottom of the dashboard rail. They go into the pemnuts on the speaker chassis.
    Does your sedan have the wraparound windshield of later cars, or the so-called "flat" windshield of earlier cars?
    If you have the wrap around windshield, the radio is configured differently for those cars. The tab that mounts the speaker/amplifier chassis mounts at a different angle to the tuner chassis than the earlier radio does. The earlier radio will not fit properly in the later sedans/wagons.
    Is your sedan the early flat windshield or the later wrap around windshield?
    What is the AC number or the S number of the radio you are installing?
  • Merwin
    started a topic Interior: Radio support arm, 1955 Commander
    Can someone sketch or send a picture of the support mechanism fot the radio in a 55 Commander sedan. The front is held in place by the dial and switch shafts and nuts. The rear part needs support, I can improvise and design my own but I'd prefer to have the original
    thanks
    Merwin Harstad
