Hint (Modification for cold-start priming)
  • Engine: Hint (Modification for cold-start priming)
    To make life a little bit easier when priming a Stude that has been sitting for a long time, I filed some groves in the washer with a chain saw file to allow the fuel to run under to avoid removing the air cleaner.
    Clever idea. However, wouldn't this also allow air through and bypass the filter element?
    Ed Sallia
    Dundee, OR
    Sol Lucet Omnibus
      It's better, safer to fill the actual float bowl, rather than just squirt gas into the carburetor.
        Yes, some air could bypass but it would be negligible.
          Mr Mike could you elaborate. How is it safer? How would you fill the float bowel? This procedure takes about three seconds. An electric fuel pump would be the obvious answer, the program I am using is where there is no electric fuel pump. What is the difference if you remove the air cleaner and squirt fuel down the throat or squirt the fuel under a washer and leave the air cleaner in place?
            You could probably locate the squeeze bottle inside the car, maybe on the transmission hump. Use a bottle with a nipple on it, attach a rubber hose then run it through the fire wall, and anchor it to your special washer on the air cleaner. That way you not have to get out and open the hood. Just give the bottle a squeeze or two, then fire it up.
              I used to do the same thing with a mustard bottle. just pop the hood and squirt a little on there. wait till it all ran in before I pulled the choke.
              I also on another have a Boat squeeze primer under the frame, that works well too.
                Every carbureted light aircraft has an internal priming system that squirts fuel directly into the intake manifold, this may be my next project.
                  My neighbor trashed a tractor engine because there was a tiny hole between the air cleaner and the engine; I would not advise doing this.
                    My vehicle doesn't have any bowels but to fill the fuel bowl I use a small squirt bottle and fill through the vent tubes.
                      I accept the correction on my spelling and I think your idea to fill the bowl is a good idea I will try that next time and I think I will turn my washer over to not allow unfiltered air to enter and trash my engine.
                        I just loosen the wing nut, put the gas in, and tighten the wing nut after the engine starts.
                        60V-L6 - 60 Lark convertible
