A 56 Hawk Tachometer will work on a 57 Hawk?...
  • Electrical: A 56 Hawk Tachometer will work on a 57 Hawk?...
    Hi, Please need some help, i am restoring my 57 Hawk Dash, I Get a 56 Hawk Tachometer.... As much as I look at it, I don't notice a difference with 57 ( but I only know 57 for pics that I've seen)... 56 is supposed to be 6 volts and 57 is 12 volts ... I'm afraid to connect it and burn it ... please help!
    I don't know where you read that '56's are 6 Volt, but they are not.
    IF your Tach. was not from a '55 President Speedster, it is not 6 Volts, the Design would be way different anyway.
    The Tachs. used from '56 to '61 are all the same and 12 Volts.
      Don't forget, you need the sending unit from the the dist. !- Jim
        And a '56 Golden Hawk sending unit will not work on a '57 Golden Hawk.
          Agree. To clarify, the reason a 56GH sender won't work on a 57GH is because the rotor button and distributor cap are different.
          OTOH, will a 55 Speedster sender work on a 57GH?
            Ok, Perfect, You have been very helpful, thank you very much!
              Will the mesh grill insert from a 63 Hawk GT bolt into the Schell of a 62 Hawk G T
              thanks. Hawkowner
