94-04 Mustang GT/Cobra brakes on a Stude - How to
  • 94-04 Mustang GT/Cobra brakes on a Stude - How to
    Originally posted Posted - 02/23/2006 : 01:34:35 AM
    The original post was locked/archived, so I could not update the links
    for the pictures, so here is a repost :
    Edit per new picture location : 12/1/08
    Well ... I guess I will share what I have been doing on my Avanti
    lately. As many of you might remember I bought a set of rims for
    it - 2003 Mustang Cobra rims.
    Well, one problem I found that I had was the rim would contact the
    upper A-arm pivot in the front on a turn, this is bad for the rim!
    I contacted a guy back east who sells a 12 inch rotor disc brake
    setup that bolts on. The problem - its $650 plus shipping. I also
    want to upgrade my rear brakes, he sells a rear disc kit, but there
    is another problem - its $450 plus shipping.[V] I wouldnt be that
    concerned, but after sending out the $4250 check to the RIAA, I dont
    have much left over for the mortgage, let alone brakes for a car I
    rarely drive. The Avanti brakes need to be completely refurbished,
    so even if I decided to keep the stock brakes, I am looking at over
    1500 dollars in vintage discontinued brake parts ...
    But .. along came my Mustang friend. See, Ford uses the SAME 5 on 4.5
    inch wheel pattern (obviously since I could bolt the rims on) so the
    rotors will fit my hubs also. My Mustang friend GAVE me his whole
    1998 GT disc setup when he upgraded to Cobra brakes. 11 inch vented
    front rotors, calipers, rear solid rotors, calipers (with parking
    brake), and axle brackets. Since I am a CAD operator, I took the
    dimensions of the bracket, and drew them up in CAD, I also got the
    dimensions from the Dana 44 axle. It looks like the rear setup will
    require some milling to thin the bracket a bit to move the mounting
    surface out, and then a bolt pattern change, and open up one side so
    it can slip over the axle tube and mount on the backside of the axle
    flange. It will use three bolts to attach, which is common with a
    disc brake caliper retrofit. The rotor will fit over the hub, and it
    looks like the tapered backside of the stud holes, will nicely center
    the rotor on the studs. Hopefully I can have the brackets modified
    this next week at my work.
    The front is a different story. I didnt get brackets, as the caliper
    mounts to the spindle. I did some research and found a guy who makes
    brackets to mount 03 Cobra brakes on a first Gen Mustang. I pulled
    the image off his website and then imported it into CAD, then traced
    it to get the basic angle and spacing from hub center for the caliper.
    This is important to keep, as bleeding would become difficult! So,
    armed with this new info, I felt good about using the GT front brakes
    as well, you have more drive to adapt something when you get it for
    free!! But, I ran into a problem. The Stude wheel hub is a larger
    diameter then the inside diameter of the Ford rotor! darn! This is
    not the end of the world, as I can have the wheel hub machined to the
    right size, removing metal is easier then putting it back. The rotors
    on the Avanti are junk anyway. So I wasnt able to take the next step
    of dimensions, so that I could continue with my brackets. I did some
    research tonight on the web, looking to see if there was a hub that is
    the right size for the rotor, that would fit my spindle - no dice. I
    would rather use the Stude hub if I can, and the bearings are still
    available. Interesting though, the 1994-04 Mustang hubs are NOT able
    to be repaired! You can NOT put in new bearings! No joke! Now I
    could get the hubs from my buddy (he mentioned that a bearing is now
    making some noise, and then have my buddy at work machine the inside
    to fit the Stude bearings, but .. thats a pain (though a possibility).
    Back to the spacing problem, it looks as though moving the wheel out
    1/4 inch will solve the clearance problem. The Stude rotor is mounted
    on the backside of the hub, so it doesnt effect wheel position, but the
    Mustang rotor is on the outside, between the rim and hub,
    Sorry about the focus on some of these pictures ....
    The Studebaker hubs are now modified to accept the Ford rotors with the rotor lug
    holes drilled out to the next SAE size - 5/8. The original Ford rotor holes being
    metric these days. Here is the stock hub after separation - before mod :
    The Ford rotor is 5.6 inchs in diameter where the hub needs to fit, the outside of
    the hub was turned down to 5.5 inches, if you were to want to go with the Cobra
    13 inch rotor from the start, I am assuming that the Cobra has more room in the
    back, but this is not verified yet. I know that the rear rotor will fit the stock Stude
    hub without being turned down:
    I used Chrysler wheel studs, which are for a 1/2 and 3/4 ton truck from the 70's
    all the way to 2003 - nice huh? Wide array of availability. Napa part number is
    BK6412184, they come in boxes of 5. The only problem in using them is they are
    for a larger hole. The Stude knurl is .645, but the knurl on these studs is .668. I
    used a 21/32 drill to give me ~.012 of interference fit, then added Loctite. It is
    pretty easy to do, with a hand drill and a vice. The studs are 1 3/4 inch long, with
    a shoulder that would extend out to center the rotor.
    I found that the old Stude rotor makes a perfect holder for the hub when pressing
    the studs in, nice and stable. I might mention that one of the hubs on my Avanti
    was a drum brake hub, with a disc pressed on the back, so I know that this will
    work for either hubs. I found that the disc brake hub, accepted the stud straighter
    then the drum brake hub. This is because the drum brake hub is not machined on
    the back. This was easy enough to "fix", by putting the rotor on the hub, and then
    tightening the wheel on to draw the rotor onto the hub. This straightened the studs
    to the correct position (since the tapered hole in the rim will force the stud to
    perpendicular to the hub face). I didnt have to do this with the disc brake hub.
    Tom
      Here is the finished hub - ready for a Ford rotor!
      Here is the difference between the stud rotor and the Ford, the Stud is non-vented
      and only about 3/8 thick, each half of the Ford rotor is 3/8 thick. The Stude one
      worked great in its day, and still is good for a few stops, but I wouldnt trust it on
      a twisty auto cross course!
      Here is the dinky little bracket that holds the stock Stude caliper in place, it only
      uses three of the available 6 holes, and mounts on the back side.
      Compared to a Craftsmen 9/16 wrench .... so cute!
      Here is the hub and the spindle flange just waiting for the new brackets to come
      out of my head:
      Sorry, I didnt get a shot of the rotor on because the battery in the cam died, but it
      does fit and spins true. The thickness of the rotor made the passenger side clear
      perfectly and the drivers side almost clear the upper A-arm. It is driveable now (if
      the brakes worked), I think that I will use an 1/8 spacer in between the rotor and
      the wheel, the wheel studs are long enough to handle this. They are larger studs
      then Ford used anyway. I took all the dimensions that I needed to draw up the
      brackets in CAD, they look fairly simple to do.
      Tom
        Well ... here is the next step in the Mustang GT brake project : test bracket. Its
        always best when prototyping, to test your dimensions before going to metal. I
        used some masonite to fab a rough bracket and test the design.
        Here is the test bracket mounted on the spindle :
        The large radius is to clear the massive wheel cylinder on the front caliper.
        Here is the modified Studebaker hub mounted on the spindle:
        Then we slip the Mustang rotor over the studs (with the metric holes drilled to the
        next size SAE : 5/8):
        And finally test fit the caliper onto the bracket to see how we did:
        Turned out that I got pretty close on my first try. The only drawback was the lower
        caliper bolt is right in line with the steering arm on the spindle. Not really a HUGE
        problem, there are some tools that will allow the torquing of the bottom bolt, its
        just nice when everything clears perfectly. Other then that, all looked great, now
        to mill some 6061-T6!
        Tom
          Masonite just doesnt compare to the look of machined aluminum. My work has a
          lot of odd sized 6061-T6 scrap laying around, and even though my first choice was
          to go with 7075-T6, you can not beat the price of free. Doing a comparison in the
          strength of each, and steel .. the yeild and the expansion, it seemed that 7075 was
          overkill anyway. But, I used 3/4 thick 6061-T6 - just in case.
          Here is the drivers side bracket mounted on the spindle :
          Using 3/4 inch thick aluminum gave me the opportunity to create a grease cavity
          in the back side of the bracket. This is something that Studebaker used at all four
          corners of the car, it is there so that if a grease seal was to fail .. the grease will
          ooze harmlessly out the back .. and not end up on the drum or disc.
          Here is a view from further back, sorry about all the grime and crud, I wasnt in the
          mood to clean any more then I have too to check fitment. Once I swap out the GT
          rotor and caliper for the big Cobra stuff, I will scrape and paint everything.
          Here is the hub back on, and as you can see, designed in the bracket inner dia lets
          the hub sit inside of it ... so if the grease seal fails ...
          Now on to the passenger side, a mirrored bracket :
          The rotor and caliper mounted :
          There they be! Ofcourse the next step is to attach the Mustang brake lines to the
          Studebaker frame, and for that the factory Mustang brackets didnt work, and the
          factory Studebaker ones didnt either. So ... time to cut and bend and weld!
          Tom
            After jacking the car up so that the wheels dangled, I figured that THIS would be
            the "Worst Case" senario for the rubber brake hoses. I would end up trying quite
            a few different locations and angles of the hose end before decideing on the best
            position. The hose needed to be able to flex without rubbing anything throughout
            the travel of the suspension and the turning of the wheel. What a pain! I found
            that the stock Mustang brackets needed to be 90 degrees from what they were.
            So I cut off the "business end" and then bought some steel stock. I wanted to use
            the existing holes in the frame to bolt it down and locate it so that it wouldnt turn.
            Here they are!! :
            I dont know how to weld, but the supervisor of the machine shop will weld simple
            parts for fast food fries. These cost me a large fry from Mc Donalds. This next pic
            shows WHERE these go, I bet now it makes sense.
            A close up ... pretty aint she?
            And of course one for the other side as well :
            The hoses dont contact anything when the wheels turn back and forth and the only
            modification to the hose was an adapter fitting on the DRIVERS side to turn the
            larger flare to the size Studebaker uses. Strange, but the PASS side was the same
            size as Studebaker and didnt need to be changed. The wrench needed to tighten
            the hose was a metric, but the flare was SAE - go figure.
            My dad and I drove around and the brakes worked AMAZINGLY well. I had hoped
            for an improvement, but there is NO comparison. Granted the old brakes were in
            pretty bad condition, but the addition of a vented rotor will help cooling. I plan on
            switching to the 13 inch Cobra brakes as soon as I get my tax refund. My dad
            wants the GT parts for his Avanti.
            Is anyone interested in something like this being marketed? I feel that by using
            the original hubs, it really reduces waste, and doesnt require buying hard to find
            rotors or using sleeves. Not to put down the great work that others have done to
            keep Studes on the road, but I think there is always room for another viewpoint.
            Shoot me an email if interested : sbca96@aol.com
            Now I am working on the rear disc setup ... the brackets are done, and on the axle
            and I am modifiying the hubs with the Dodge wheel studs. The outer dia of the hub
            doesnt need to be machined down, because the inner dia of the Mustang rotor is
            larger then the front and the Stude hub is smaller - perfect fit. The rotors actually
            fit fine, but its recommended to have at LEAST 8 threads of contact on wheel studs
            and I was at 5 with the stock length studs. I ordered the stock Mustang rear hoses
            for the setup, because I didnt get those from my friend. I was happy to find that
            Autozone includes the banjo bolt in the hose kit. Before you laugh, they are nice
            hoses made by Wagner. Now I have to figure out the plumbing, once I get all the
            wheel studs in ... had a mishap with one of the 5 studs I COULD get (darn the
            StupidBowl, most the autoparts stores closed early today!), it contacted the socket
            that I was using when pressing the stud in, and ruined the threads on the stud.
            GRRRRRRRR!
            Oh well .. gotta buy 6 tomorrow now.
            I must also mention that "Bobby" the machinist thats been doing all the work for
            me after hours, has been absolutely wonderful. If it wasnt for his patience with
            the sometimes last minute and "on the fly" design changes this wouldnt have even
            happened. Even the slight "correction" that we had to do on the rear brake caliper
            brackets he didnt cringe (much) at. Thanks Bobby!! You dah Man!
            Tom
              I thought that I would share what the Cobra brakes will look like, the calipers
              come in both black and red (that I am aware of) and are actually 2 piston, not
              4 piston like I had originally mentioned (thanks Ed and Eric for setting me
              straight on that!). I got confused with the Baer 4 piston setup that my friend
              had converted to (which got me the GT brakes!). If memory serves there is
              an 8 piston caliper also available, but thats CRAZY talk!
              These images were "borrowed" from
              http://www.edbert.net/brakes.htm .
              After doing brake pads on my 1993 Camaro Z28 for the last 10 years, I had
              thought that the Stude hubs could be modified to allow a "slip-on" rotor to be
              used (like most newer cars). After finding out that Ford still used the same
              bolt pattern as years ago, I knew that the Ford rotors would fit. After getting
              Ed's brakes .. it all came together. When looking for the dimensions of the
              angle of the caliper position, I came across "Mustang Steve" who makes a kit
              that allows the installation of Cobra brakes on a first gen Mustang. It was his
              website that I got the angle I needed. He was also very helpful by telling me
              that Ford still used SAE flare thread (http://www.mustangsteve.com/).
              10 inch rotor compared to the 13 inch Cobra:
              Other assorted views :
              I checked the fitment of a stock Studebaker wheel on the new brake setup, it WILL
              NOT fit, due to the caliper being out farther to the wheel. This brake setup
              would require upgrading to wheels that fit a 1994 to 2004 Mustang. This can
              be viewed as good OR bad depending on your perspective. At least with the 11
              inch GT Mustang calipers, you can run a 15" wheel. I have been told that this
              can be done with a Lincoln Towncar (early '90's) 6.5" rim width and the offset
              is ~0.5" farther out than Stude. I havent checked this personally though it
              sounds like it would allow the use of the 11" rotor/GT caliper and Stude full
              size wheel covers.
              Tom
                Tom,
                Did you happen to pull the following dimensions from your spindle,
                Inner bearing surface measurement
                outer bearing surface measurement
                and total length of spindle?
                I have a 48-49 champion that I am going to convert to disc brakes. I was out at the salvage yards pulling rotors and measuring spindles.
                My spindle is 1.25" at the inner and .75" on the outer. I need to re-measure the spindle length as my notes mysteriously vanished .
                I'm not familure with Avanti's but it looks like stock they run a hub assembly on the spindle?
                This would be ideal as it is the route I've been looking to do. I'm finding all ford stuff from 92 up do not run a "tapered" spindle and hub. However I am finding other makes that are. I'm hoping to get back out to a different salvage yard to know for sure.
                  Instead of milling the rear end for disc brakes look at the 8.8 rear ends from late 1980 to early 1990 Ford Explorer. They come with a disc brake setup (earlier models are drum brakes which are easily converted to disc brakes. Lokar makes a cable hookup kit for the park brake. The only change you will need is to remove the spring pad mounts and move them about 3/4". For the Hawk models this rear end is a stouter unit than the Dana 44.
                    wow! very nice! Better stopping AND replaceable parts!
                    --george
                    1963 Lark Daytona HT - 63V J8 175
                      I think you will be pretty much SOL finding a modern hub that will fit
                      the Studebaker spindle. I didnt bother to measure the spindle because
                      I just reused the Studebaker hub. That simplifies the install. This
                      is what the modern cars do, Studebaker did this to some degree, as the
                      hubs & drums, and hubs & discs are two piece. The drums are between
                      the wheel and hub, where as the discs are held to the backside of the
                      hub with special wheel studs. I just moved the disc to the outside as
                      the modern cars are. If you are planning something of this nature, I
                      would suggest using your factory hub, and keep that relationship fixed.
                      I hope that helps.
                      Thanks for the input, but as this is a repost, I have already been
                      running the matching Mustang setup on the rear, it was completed in
                      the months following the original post. I have to find the text to
                      it and I can repost it here to keep the info together. The install
                      is pretty much like the front, with the Ford brackets being redrilled
                      to mount the caliper to the Dana 44. I still havent done the parking
                      brake, but Karl had put something together. The Mustang rear caliper
                      is the same for the Cobra and the GT (for the most part) and use a
                      pull type setup. The mod looks very easy, its just been backburnered.
                      Thanks George. If you wish to be added to the update list I am doing
                      CNC brackets, one set is still available at this time.
                      Tom
                        Tom
                        Thanks for a great article. Wish I had known this when I added discs to my 54.
                        Tim
                        I think you need to look for mid 80's GM midsize rotors, possibly Monte Carlo. They require a new set of bearings with GM OD's and Studebaker ID's. A pretty standard way of changing hubs over the years. Of course, the down side is incorrect bolt pattern, no bad to change.
                        Bob
                          Bob,
                          In my looking around besides going to the salvage yard to get some hubs I was thinking back to the farm and remembered we used hubs on all our trailers. I did some looking and sure enough I can get them in what ever bolt pattern and bearing combo I would need. They are pretty cheap new as well. My only hang up would be knowing the exact spindle length they require vs a car hub.
                          I'll check the GM cars too. Plenty of those in the junk yard for sure.
                            Tim
                            Measure the Stude hub from bearing outside to outside, same with the hub you are examining. I'll bet they are close. If one is wider, I'll bet it is the Stude hub. The difference is the width of the spacer needed.
                            Be sure to buy new rotors, they are cheap as are the rest of the parts. What you are doing is the same as assembling a kit to convert early ford hubs to disc brakes.
                            Bob
                              Curious why you dont want to use the factory hubs? The bolt pattern
                              is something oddball? It was critical for me to keep the stock spacing
                              between the bearings. I didnt want to stress the spindle by moving
                              the load in or out. Studebaker spindles are quite long, I dont know
                              if that is true for the earlier years. Late model cars use assemblies
                              that arent usually rebuildable. The whole spindle/hub is replaced as
                              a unit, held in place by 4 bolts at each wheel. The Stude spindle is
                              smaller in diameter than these modern setups. I guess thats how they
                              get away with moving the bears closer together.
                              There are a number of different modern bolt patterns available. Ford
                              still uses the Studebaker one, GM has two 5 on 5 and 5 on 4 3/4.
                              I wish the original thread was a sticky, so more could see what I did.
                              I've invested money into having the brackets made by a local CNC shop.
                              As I mentioned I have to design the final rear bracket, though a proto
                              exists on my Avanti already. The reason this is a herdle, the GT is
                              a smaller rotor than the Cobra. The caliper is the same, so they made
                              the bracket hole spacing from center different. To make brackets I'm
                              hoping to make one bracket that does both applications. The front is
                              already this way, Ford used three different calipers in the front. I
                              hope that makes sense.
                              Tom
