54 Hardtop brake upgrade
  • 54 Hardtop brake upgrade
    I can't help, but I've got to ask...why? There must be some advantage to a hanging brake pedal, but I can't figure out what it is.
    The under floor MC (IMHO) makes for the shortest, strongest, most direct, least flexing, pedal to MC linkage. It also keeps the engine compartment clean of all that semi unattractive brake stuff.
    I guess the MC is easier to check and fill with a hanging pedal. What else am I missing?
    Bellingham, WA
    Bellingham, WA
      I'm with Dick. Why mess with a good thing?
        Dick,
        Even adding fluid wouldn't be a problem if a remote resevoir(sp) (like on disc brake 63'&64' Hawks) were added....real simple addition.
        Dan Miller
          Thanks for your feed back guys.
          The original m/c has been removed & replaced with a larger unit(extends up into the passenger compartment)which is mounted to a piece of fabbed steel angle. The pedal assy. has also been re-worked extensively( improper geometry, does not work).
          My thinking is to repair this I would have to cut out the angle, replace the m/c & pedal assy and still NOT have power assist brakes.
          From what I read on the forum, I am not too impressed with hydro-vac's either-they suck
          1954 Starliner Hardtop
          Tacoma,Washington
            Jim Turner sells a more elegant dual master cylinder conversion then the home made version on your car. It won't stick into the passenger area.
            JDP
            Arnold Md.
            Studebaker On The Net
            http://stude.com
            My Ebay Items
            http://www.stude.com/EBAY/
            64 Daytona HT
            63 R2 4 speed GT Hawk
            63 Avanti R1/AC
            63 Lark 2 dr.
            62 Lark 2 door
            60 Hawk
            52 Starlight
            52 Starliner
            51 Commander
            JDP Maryland
              That's one thing I'm glad I have on my Daytona; it came originally with a dual master cylinder.
              _____________________________________
              Matthew Burnette
              Hazlehurst, Georgia
              '59 Scotsman PU
              '63 Daytona HT
              http://thestudillac.blogspot.com/
                Tim,
                I should have recognized your name...but I do recognize that picture . I still can't help any with the hanging pedals, but you might evaluate the cost and time of doing that vs bringing your's back to a stock set up so you can still use the underfloor system. My guess is that the later might be easier and better. If you want power brakes, you can use a Midland remote booster or something like this...
                http://www.classicperform.com/Instru...PDF/Remote.pdf
                You may not need a booster if the system is engineered correctly. Talk to Jim Turner.
                Bellingham, WA
                Bellingham, WA
                  The discussions on this forum regarding the Hydrovac are typically from those in which the units were not properly maintained. Hydrovacs work fine if they are serviced per the manual. They do not suck if you do what is supposed to be done, as with any brake component!!!!! Hydrovacs were used for many years by many manufacturers, including Mercedes, Ford, Jeep, Chevy, Cadillac, etc. In fact Ford used the Hydrovac on their trucks and certain cars through '79, maybe beyond, including Lincoln! Lamborghini also used the hydrovac units as well. Get a rebuilt unit and make sure you mount it properly and it will work just fine.
                  Dan White
                  64 R1 GT
                  64 R2 GT
                  Dan White
                  64 R1 GT
                  64 R2 GT
                  58 C Cab
                  57 Broadmoor (Marvin)
                    Thanks guys,
                    this forum is awsome for getting different perspectives
                    Dick, you have made a solid argument, for sticking to the oem location.
                    I will re-consider.[^]
                    Tacoma,Washington
