Overdrive wiring
  • Transmission / Overdrive: Overdrive wiring
    I'm finishing up my 63 Champ and am wiring the Overdrive circuit. Seems to be several schematics both with and without a relay. The main issue I'm having is mine has a Shift Rail "Lockout" switch between the Governor and Kickdown switch. Not sure what it is for or if I should just bypass it.
    Thanks
    My 8E5 has that switch and it is not used , Ed
      Relays were not used after 1957. The lockout switch was eliminated during the 1955 model year, so you must have an older transmission.
      So.....if I'm 'pre-approved' why do you want me to fill out an application?
        It is a REVERSE Lockout Switch, if you do not plan on going 32 Miles per hour in Reverse in Overdrive, I don't think you will ever need it!
        What Engine does your Champ have?
          My 8E5 Champ was not factory equipped with OD. Previous owner installed OD but didn't bother to wire it or to even install proper accelerator linkage. When I finally secured necessary parts I used wiring diagram shown on page 4 of wiring diagrams in the 2E through 8E Truck Shop Manual.
            Overdrive will not turn in reverse when engaged, has a one way clutch.
              It has a 170 straight 6 with 455 rear so it needs OD. Not sure what the PO did but I have to re-wire OD from scratch. I have yet to find a diagram that doesn't include a relay or a diagram of the relay itself. Does anyone have a OD diagram that doesn't show a relay? Maybe one that shows the internals of the relay.
                This is one I used. I printed the diagram and then used colored pencils to highlight the wires I needed.
                  Here's my diagram:Click image for larger version
Name:	OVERDRIVE DIAGRAM clean my 62 GT rev3-2.jpg
                    OK, following those diagrams, this one from Borg-Warner seems like a simplified version. The relay is simply breaking positive power to the solenoid so there isn't 24/7 power to it.
Name:	Overdrive Wiring.jpg
