Installing control arm bushings
  • Installing control arm bushings
    I've been thinking a lot about how to press new bushings in and out of my old A-arms and searching for ways to do it without having to hunt down someone with the original Kent-Moore tool set, or trying to jury-rig my own.
    I found a bushing-installer set from Minnesota Pneumatic that purports to do the job:
    The description is as follows:
    "Remove and install control arm bushings. Includes all adapters. Easily replace press-in type upper control arm bushings on most rear wheel drive Ford, GM and Chrysler vehicles. Mechanical screw power quickly removes the old bushing and installs the new one without damaging the control arm. Includes c-frame, screw assembly, and all adapters and inserts necessary to do the job correctly."
    Whaddyou guys think? Look like it'll do the job? Anyone used one? [?]
    Clark in San Diego
    '63 F2/Lark Standard
    If it does the job without having to pull thr "A" arms & doing the bushings on a bench it sounds good to me !
      Clark in San Diego
      Looks like a good, sturdy tool.
      Do double-check the available room in the car if you have hopes of being able to replace the bushings without removing the control arms.
        I don't mind removing the arms from the car... just don't want to have to find someone who'll let me borrow their press, fab the installer, etc. etc.
        BTW, I found this at www.sastool.com. Right on their homepage.
        Clark in San Diego
          I'd love to try one!
          Clark - try clicking on that link you gave us.[}]
          Miscreant adrift in
          the BerStuda Triangle!!
            That is the exact press I used in removing and installing the bushings in my control arms (62 lark). It works ok, I had the motor out and the clip off it was still pretty hard to wiggle that thing in there. Also the steering box needed removed and the tie rods were disconected from the bell crank. Now even with that press getting the bushing out proved quite difficult requiring time, patients, three people, pry bars, and lots of heat. installing the bushings wasnt bad, one did pop out and i had to repress it in. it probably should be noted that i did this with the springs in place so i had to be very careful not to get carried away and knock the control arm off the shaft(i left the bolts in the shafts). Im not bashing this tool it works great its just a little tight in some places. good luck
              Never knew it took sick people to do this job!
                We are all sick Guido. We have Studebakeritis!
                  D'oh! One too many esses [:I] Try this instead:
                  http://www.sastool.com/
                  Clark in San Diego
                    Looks like something Harbor Freight has also.
                    I actually changed mine on the Hawk years ago "old school". I used a
                    short handled sledge hammer, one WACK knocked them out, a couple hits
                    with a socket over the end to contact the metal on the bushing was all
                    that was needed to get them back in. I used a floor jack under the
                    lower control arm, and removed the two bolts that hold the upper arm
                    to the frame. Removed the cap screws, and flipped the arm over so the
                    inner bushings were facing out. In my case the lower bushings were in
                    decent shape, the uppers were toast.
                    Tom
