Just read an old post on oil pressure and was reminded of some prior misery I'd like to warn you all about.
I needed to change oil & filter and in my small town there was only one filter available, a Fram. I normally won't use this garbage because their anti-backflow valve is cardboard which causes some great engine rattles & clatter at start up. I decided to use the Fram temporarily until I could get a WIX filter or NAPA Gold.
Noticed the box said, "Contains PTFE Teflon Protection" and thought maybe Fram had started cleaning up their act: NOT!
Before installing that junk filter I had 80+ lbs running pressure & 60 lbs idle in my 360-3 Premium block Mopar. Lowest pressure I would ever see was 75 lbs/55lbs.
After filter installation and refill with premium Valvoline 10W-40 the oil pressure dropped to 60-65 lbs running pressure, 30 lbs at idle! WHAT?!! I ran it for a couple of days and yanked it, drained oil hot, installed a WIX. Too late! That engine NEVER came back up for oil pressure and for the next 50K until I pulled it to install a Cummins it had lousy oil pressure.
No idea what kind of junkola chemical formula Fram calls PTFE Teflon but it put a real real hurt on my engine. Buyer beware....
