The drip that won't quit
  • The drip that won't quit
    Hi all,
    I've spent about an hour troubleshooting a fuel leak that I cannot fix. The leak is right at the union of the pipe and its attaching nut, on the end that screws into the fuel pump fitting (as shown in the pic below).
    I've R&R'd it about 5 times, adjusted the fitting angle on both the fuel pump end and the carb end, and still gas comes welling up out of this joint. The nut is as tight as I can get it - I'm certain it's bottoming out in the 90-degree fitting.
    Any suggestions as to how to fix this? I'd really like to run my engine The fuel pipe is from SASCO; it's for a '62 Lark with a WCFB (since that's what I'm running).
    Clark in San Diego
    '63 F2/Lark Standard
    The Official Website of the San Diego Chapter of the Studebaker Drivers Club. Serving San Diego County
    That brass elbow isn't cross-threaded, is it? My eyes might be playing tricks on me, but that's what I think I see. (the line looks lop-sided)
    StudeDave '57 [8D]
    StudeDave '57
    US Navy (retired)
    SDC Member since 1985
    past President
    Whatcom County Chapter SDC
    San Diego Chapter SDC
    past Vice President
    North Florida Chapter SDC
      Try this, just a guess.
      Wrap the end of the flared pipe and the threads with teflon tape. Tighten them down and try it.
      Tom Bredehoft
      (Under Construction 510 hrs.)
      '05 Legacy Ltd Wagon
      All Indiana built cars
        I'll pull the elbow off and check the threads, Dave.
        Tom, I thought you weren't supposed to use Teflon tape on fuel line?
        Clark in San Diego
          In that case I'd suggest the paste, but that probably wouldn't be an improvement. I understand, I had a similar problem with my 55, I thought I was going to bend the brass before it stopped leaking, but it didn't bend and did stop leaking.
          Tom Bredehoft
            I'd pull the elbow, check the seat and check the seat on the line where it screws into the elbow. There could be a problem with the seat or possibly a hairline crack. You might check the seat inside the elbow to see if it has a flare seat. Could be a pipe fitting and not a flare.
              You should not have to use Teflon tape or paste. The flare and the seat make the seal, not the threads. If nessessary, replace the brass fitting and make a new double flare on the end of the line. Hope this helps.
              Dan Miller
              Atlanta, GA
                I agree on the seat vs the flair on the tube. Pull the whole line off and look at the flair in relation to the nut. Is the flair spread out far enough, is a nice full circle matching the nut and is there are mark on the brass to indicate that it's not seating completely against the seat.
                ErnieR
                  If that leak is coming from between the pipe and the fitting, which is what it looks like, your problem has to be in the pipe flair not seating against the brass fitting. Did the nut and fitting come as a set or did you use different 'sources' for the 2 pieces? If they didn't come together, they might not be mated properly between 2 manufacturers. The nut may not be threading into the fitting far enough to squeeze the pipe flair. Can you feel ANY looseness in the pipe length? Is there a crack lengthwise in the pipe? That can happen to old steel.
                  '50 Champion, 1 family owner
                    Years ago, I was told by Autometer, that teflon liquid should be used on fuel lines vs teflon tape..
                    Bob Johnstone
                    55 President State Sedan
                    64 GT Hawk
                    70 Avanti (R3)
                    1970 Avanti (SBC, R3)
                      I put my dual carb setup together by myself, and my mechanic tested it recently - gas leaking everywhere! He mentioned that I should have used fuel line instead of brake line. I thought they were the same, but he went on to say that the right line for fuel fittings is an inverted flare, not a double flare. Any experts out there who can shed light on this?
                      [img=left]http://simps.us/studebaker/misc/images/Avacar-hcsdc.gif[/img=left]
                      Paul Simpson
                      "DilloCrafter"
                      1955 1/2 Ton Pickup
                      The Red-Headed Amazon
                      Deep in the heart of Texas
                      Paul Simpson
                      "DilloCrafter"
                      1955 1/2 Ton Pickup
                        I've never heard of that. A double flair is used universally. It's stronger and less prone to cracking.
                        ErnieR
                        Paul Simpson
                        "DilloCrafter"
                        1955 1/2 Ton Pickup
                          I probably just misunderstood him.
                          Paul Simpson
                          "DilloCrafter"
                          1955 1/2 Ton Pickup
                          Paul Simpson
                          "DilloCrafter"
                          1955 1/2 Ton Pickup
                            You would use the liquid on pipe style threads, a piece of tape could break off the tape and clog something. On flair syle fittings the sealing is between the flair and the seat.
                            ErnieR
                            Bob Johnstone
                            64 GT Hawk
                            70 Avanti (R3)
                              It sure looks like the nut is cross threaded!!!
