dg 200 transmission?
  • dg 200 transmission?
    can someone tell me the correct amount of fluid that a dg200 transmission takes in the 1954 commander coupe? Thanks
    Domenic Manera, Fire Chief
    City of York Fire Department
    York, SC 29745
    1954 Regal Starlight Coupe
    The book says 9&1/2 qrts, or 11&1/2 qrts, depending on which year and which model. These fluid levels are with torque convertor drained, which is advised. For safety, set the parking brake and chock at least one wheel, on both sides of the tire. Begin by adding 6 qrts., start engine, run for aprox. 1 minute with gear selector in Low. With engine still idling, and selector still in Low, add 3 more qrts. Shift the selector through all ranges, let it warm up, make final check, with selector in Low, add as nessessary. Do not over-fill. This info. is directly from the Studebaker Automatic Drive Shop Manusl.
    Hope this helps.
    Dan Miller
      Thanks for your info. Very helpful.
      York, SC 29745
