Cam shaft lobe question
  • Cam shaft lobe question
    Does anyone know the runout on the cam lobe that the fuel pump runs off of? thanks.
    What year and CID??
      oh geez that was dumb. lol.. 56 power hawk, 259 v8
        All '55 to '64 V-8 Fuel Pump Cam Lobes are the same, with the exception of the (4) types of R Series Engines, in spite of the Lark/Hawk Chassis Parts Manual error.
        In other words contrary to common belief, to run at it's optimum, the R Series large bowl Carter Super Pump needs the unobtainium R1-4 Fuel Pump Cam Lobe! [:0]
        Studebakers Northwest
        Ferndale, WA
          I think the number you are looking for is .260, + or - .010. You don't say whether the cam is in or out of the engine. If it's in
          you could probably use a dial indicator to make the measurement.
          Hope this helps.
            yeah cam is in the engine still
              It might be helpful to have some information on the issue you're
              having with your fuel pump. Is it pumping? The measurement of
              .260 inch should be a good starting point to check whether the cam
              is doing its job.
