Fuel gage sending unit gasket
  • Fuel gage sending unit gasket
    Hello, everyone.
    Due to a leak, I need to replace the gasket at the gage sending unit on the fuel tank of my '62 Lark Cruiser.
    Should I use any sort of gasket sealant or adhesive when installing the new gasket?
    Thanks!
    Tom
    Tom
    1960 Lark VIII
    1962 Lark Cruiser
    1964 Cruiser
    259 - NO SEALANT OR ADHESIVE IS NECESSARY, JUST MAKE SURE THE GASKET SURFACE IS CLEAN
    Studebaker Fever
    60 Lark
    51 Champion
    Phil
    Arnold, Missouri
    Studebaker Fever
    60 Lark
    56 Power Hawk
    Phil Hendrickson
    Arnold, Missouri
      I made one out of the sheets of cork from a auto or industrial supply
      No adhesive was used ,it was in the car 9yrs.with no problems & as far as I know still is.
      Be sure to disconnect the battery when working in that area to prevent possibility of sparks or KA-BOOM !
        Same stuff I use, except mine has the 3M adhesive on one side. Cut out the gasket, punch the holes, and then peel off the paper and stick the gasket on the sending unit. Then you don't have to worry about lining the gasket up and keeping it lined up while you put the first couple of screws in.
        Paul
        Visit The Studebaker Skytop Registry website at: http://hometown.aol.com/r1skytop/myhomepage/index.html
        Paul
        Winston-Salem, NC
          Thanks for the advice, everyone.
          It'll be nice to fill up the tank without leaking fuel and stinking up the barn in the process!
          Thanks again.
          Tom
          Tom
          1960 Lark VIII
          1962 Lark Cruiser
          1964 Cruiser
