How do I get my thermostat out?
  • How do I get my thermostat out?
    Dumb question here, but...
    I'm trying to get the thermostat out of my water manifold, but it is stuck fast in there (brass + iron + corrosion = stuck ).
    Any suggestions on how to remove it?
    Clark in San Diego
    '63 F2/Lark Standard
    If you dont care about ruining it, just stick a big screw driver into
    the center of the T-Stat and move to one side, the opposite side will
    pop up and out of the manifold. If you are trying to save it, then
    you can do something similar with pliers.
    Tom
      Did you try starting it up?
      '64 R2 back on da road again
      POCI,SCCA,SIMTA
        Nope - it's disassembled
        Clark in San Diego
          C L R dissolves rust & corrosion,pour some on & wait a bit,Any toilet cleaner made for rust& mineral stains will work
            Which engine (and year)?
            If it is a six cylinder with the thermostat up in the housing, it may be tough to get out without ruining the spacer sleeve... But that depends on the year and model engine.
            Clark in San Diego
            DEEPNHOCK at Gmail.com
            Brooklet, Georgia
            '61 Hawk (project)
              quote:Originally posted by DEEPNHOCK
              [navy][b]Which engine (and year)?
              '63 full-flow block, 259.
              Clark in San Diego
                Brute force should work just fine. Hammer a screwdriver through the middle of the thermostat and pry it out.
                David
                  A freshly-built engine will deserve a new thermostat. Whack that one outta there. You'd have to TRY hard to hurt the water manifold![}]
                  Miscreant adrift in
                  the BerStuda Triangle!!
                    THAT was what I wanted to hear! [}] Thanks!
                    Clark in San Diego
