Steering column seal
  • Steering column seal
    I replaced the Lark's speedo cable so I had to replace the column seal at the same time. (The old one pretty much fell about in my hands.)
    I used 3M Strip-Caulk around the column and firewall, but that seal is just cardboard... is that enough to seal out water? Should I do anything else?
    (Yes, I know it's ugly... I was going for functional, not pretty.)
    Clark in San Diego
    '63 F2/Lark Standard
    www.studebakersandiego.com
    The vendor sells the correct foam gasket and inside, rubber seal.
    JDP/Maryland
    "I'm a great believer in luck and I find the harder I work, the more I have of it."
    Thomas Jefferson
    JDP Maryland
      I got those and used them, John. But that outside seal is cardboard.
      Clark in San Diego
        This will let in quite a bit of heat. Insulate with a ceramic firewall blanket material.
        ok
