I discovered that the vibration that i have never been able to cure was caused by a buckled axle shaft. I have now installed a new axle shaft but have a few questions.
1.Before pressing the new bearing onto the axle shaft , I measured where the old bearing was located on the buckled axle shaft and tried to use the same measurement to locate the new bearing on the new shaft, The manual is not very helpful as it says you must press the bearing onto the shaft untill it is tight !
2. After placing the shaft and bearing into the axle housing
,I had to use a hammer and a piece of wood to knock the bearing cup into the the axle housing so that it located with the bearing . At that stage there was still some end play but I noticed that the bearing cup was proud of the axle housing.There were no shims when I removed the backing plate.I installed the backing plate and after tightening it all up , I noticed there was no end play , the backing plate must have pushed the bearing cup further into the axle housing.
I am now concerned that the bearing cup may be too tight against the bearing , if so ,how will I know and is this a problem ? iF so how can I sort the problem short of removing the whole assemble and pressing the bearing further onto the shaft ?
