dual points help please
  • dual points help please
    When I bought my '60 Hawk, it had dual points. I later converted to a Pertronix kit #1183 with their 1.5 ohm coil which is giving me a lot of grief and I want to go back to a points setup. Would the dual points have been stock? If not, would the mounting plate inside the distributor have to have been changed or altered to accept the dual setup?
    Thanks in advance
    Mr Mike
    The dual-points are NOT stock.
    Your car was originally equipped with a Delco 1110864 non-window distributor (V8 of course)
    Someone may have swapped in a Prestolite Dual-Point from a '63/'64 R-Engine.
    Personally, I'd go back to the 1110864 with the Pertronix unit... as I have installed and run several of them for years with no problems at all.
    IF your car has a factory Tachometer- it's easiest to just use the regular points instead... The Pertronix has clearance issues with the tach-sender
    Ray
    Ray
    www.raylinrestoration.com
      Ray
      What Ray said. But I do want to offer one more possibility.....you might have had an aftermarket 'dual point' conversion plate for the early Delco V8 distributor. These are seen regularly on eBay, and IIRC, JDP sold them for a while too.
      Was the distributor that had the dual points a Delco or a Prestolite?
      Paul
      Paul
      Winston-Salem, NC
        It is a Delco but the band with the Delco # is missing.
        Mr Mike
