R1 Pertronix Question
  • R1 Pertronix Question
    I have three questions:
    1. Now that I've installed the Ignitor to replace my dual points, should the contact points jumper wire be removed or left in place?
    2. What is the purpose of the little wire that is riveted to the timer base plate at one end and has a loop on the other end that goes around the screw holding the Ignitor base(or previously one of the points) to the timer base plate?
    3. The little wire seems pretty limp or weak; is it supposed to be that way?
    Thanks. Dan
    1. Removed, doesn't do anything any longer.
    2. Ground.
    3. Apparently!
    Just set the ring to ignitor per the instructions...connect the wires per the instructions...close it up and hit the key.
      You don't need the jumper, the weak wire is a ground and seems weak because it has to be flexible.
      JDP/Maryland
      "I'm a great believer in luck and I find the harder I work, the more I have of it."
      Thomas Jefferson
      JDP Maryland
        And if you have an Pertronixs coil, throw it out. They are made in China and less than worthless, they will cost you a tow.Better off with a '72 Maveric coil out of a junkyard.
        '64 R2 back on da road again
        POCI,SCCA,SIMTA
          I've had great luck with Pertronix coils...in fact with all their products. Very well engineered. If we threw out everything made in China, there wouldn't be much left .
          Bellingham, WA
          Bellingham, WA
            A sad reality of life in this here USofA
            Bellingham, WA
            [/quote]
