Then you install a manual Bellcrank, Reach Rod and Pitman arm all from a Manual steering car and you are done! Unless you have serious wear on the Box, it should be fine, it has been protected from road shock since new by the Hydraulic system.
The steering gears are all the same, so no need to change it.
Your car, your choice, if it were mine I would reseal the Ram, reseal the Control valve, replace 4 hoses and drive on, this is a good system, it is a Bendix System, the same as Ford used for years and has no major faults! [:0]
This system in your car has been operating for 45 years and you can not expect much more than a leaky mess, until it is rebuilt.
