63 Gt Carburator-Carter AFB 2312 OK?
  • 63 Gt Carburator-Carter AFB 2312 OK?
    My son has a Carter four barrel # 2312 he took off his 63 Corvette. It was
    for a 67, Corvette 327. Would this be OK for replacing the two barrel
    on my 63 Hawk GT? What adapters would be needed or manifold ??
    Thanks.
    ...Dick
    1950 Champion Starlight
    1963 Hawk GT
    Santa Barbara
    CA
    The 1950 Champion Starlight
    Santa Barbara
    CA
    If its for a 327, its going to be pretty closely setup for an engine
    about the size of your Hawk. Its not going to work perfect swapped
    right onto your Hawk, but it will be close enough you wont notice if
    there is a problem. "Problems" would be jetted too rich or too lean.
    You'll need to have your manifold bored out to fit an AFB, no adapter
    is going to make a 4 barrel carb fit a 2 barrel manifold, the holes
    are just not there. There is a vendor that sells 2 barrel manifolds
    that are machined to fit an AFB, I think they offer a core discount.
    You will also need the 4 barrel linkage, or can modify your own setup.
    I have a WCFB manifold modified to fit an AFB, it works pretty good.
    I also have an R1 carb from my Avanti that will be left over once I go
    to the Edelbrock carb I have from my Hawk.
    Tom
      Jeff Rice (I think) modifies two bbl manifolds to four bbl. Unfortuneately I'm having a senior moment and can't remember his company's name. Maybe someone else will. Still, it's the easiest fix for your engine. Elsewise you will need a four bbl manifold for that carb.
      By the by, nice car.[8D]
      Lotsa Larks!
      Ron Smith
      Home of the famous Mr. Ed!
      Ron Smith
        jeff Rice deepnhock@gmail.com
          Thank you all for the help.
          Tom.
          Sometime in the near future I'd like to get you to look over my Hawk
          and advise the next series of restoration steps I should take.
          I will clean up the AFB and overhaul. I think I may opt for a new AFB manifold
          so , I have the option of easily going back to the stock set up.
          Most things important are now working--current problem is a intermittent signal swiitch.
          We pulled the steering wheel and the switch is worn out. The Type C switch replacement
          is hard to find.
          ...Dick
          1963 Hawk GT
          Santa Barbara
          CA
          Santa Barbara
          CA
            I think NAPA carries one for a Chrysler that can be easily adapted.
            Tom
