wiper wiring
  • wiper wiring
    Installing the wiper switch on my 56 wagon. Went and printed the wiring diagram off this forum. Still can't tell how the wires connect to the switch. Have a black,green,yellow. I assume the black goes to the one side and the yellow and green to the other. Figure only thing bad that could happen is the speeds are reversed. Any thoughts???
    Yellow is park (P)? Green is low speed (A). Black is high speed (the other terminal). I found when I installed the intermittent switch, low speed is accomplished by sending power through both green and black wires, increasing the resistance. Cool, huh?
    '33 Rockne 10,
    '51 Commander Starlight,
    '56 Sky Hawk
      Thank You. I assume the hot wire goes to one of the remaining terminals. I still have my old harness and switch so I can figure this one out.
        I just spent an hour going through the search mode trying to get the cross referance for the switch letters. My switch has A,B and a F. I am going to assume the A is yellow, Anyone know the other two or all three? Thanks
          Ken,
          My manual is at the shop and I'm at home.[V] The diagram in the manual indicates the terminal notation. The one I can remember for certain is "A" is green.
          '33 Rockne 10,
          '56 Sky Hawk
            Can you please check and confirm. Everything I have researched says A is yellow. Mine is a 3 wire motor.
              I just installed an intermittent switch the other week. Here's my post on the subject.
              http://forum.studebakerdriversclub.c...TOPIC_ID=19805
              I'll be in the shop in the morning and check the diagram.
              '33 Rockne 10,
              '56 Sky Hawk
                ...and the diagram says,
                F terminal gets black.
                A terminal gets green.
                P terminal gets yellow.
                Remaining terminal is Battery, from the ignition switch and would be on the input side of the circuit breaker.
                '33 Rockne 10,
                '56 Sky Hawk
                  Rockne 10, Thank You. I have a F,A and a B. I will assume the B equals a P. The B(P) is by itself on one side.
                    As long as that "B" terminal is not a stud, or connected to a stud, on the circuit breaker you're probably right. Otherwise "B" could mean power from Battery. Yellow is "Park", hence the P.
                    '33 Rockne 10,
                    '56 Sky Hawk
                      No b is aoval connector as A and F. The two studes are on the end. I connected the ign power to the same on as my old one. (I left it on the harness when I took it out). The other is empty.
