V8 piston pinch bolts
  • V8 piston pinch bolts
    Once I remove the nut and washer, does the threaded rod tap out or unscrew? I've always left this to the machine shop, but I'd rather do it this time.
    Thanks.
    Western Washington, USA
    Put the nut on the opposite side and just tighten the nut and it pulls right out.
      Thanks Alan! You da man.
        Ocasionally you may need to add washers under the nut as the pin moves...but doesn't come all the way out, then put the nut back on and continue.
