OK, what's wrong? Take a guess
  • #16
    ......did you short out the points somehow ? leave the ign "on" ?
    • #17
      OK, The problem was:
      When I put the wires back on the cap I put them on in the correct order, BUT, whoever installed the distributor, installed it 180 degrees off! So, to "compenstae" for the improperly installed distributor, "whoever" just moved the plug wires so they would not have to move the distributor.
      It was driving me nuts! as I could not figure out why after adjusting the valves, it would not start!
      Maybe it was another "ASE" certified technichtion! <G>
      All is well, valves are quiet, and runs great. I still need to replace the M/C (leaks bad) and bleed the brakes.
      Again, Lee D. picked up on it and helped me "resolve" this one, Thanks Lee.
      The dist. in 180 off and someone just moving the plug wires, is sure a new one to me.
      Jim
      their Memorials!
      • #18
        I really enjoyed the body man comment bob, being a former body man myself!! A little light humor in the morning never hurts!! (LOOKING FOR THOSE LITTLE FACE THINGYS.....lol)
        60 Lark convertible
        61 Champ
        62 Daytona convertible
        63 G.T. R-2,4 speed
        63 Avanti (2)
        66 Daytona Sport Sedan
        60 Lark convertible V-8 auto
        61 Champ 1/2 ton 4 speed
        62 Champ 3/4 ton auto
        63 G.T. Hawk R-2,4 speed
        63 Avanti (2) R-1 auto
        64 Zip Van
        66 Cruiser V-8 auto
        • #19
          Thanks for the "allowance," Warren. Jim and I spar back and forth on that all the time...always in jest, of course...so I couldn't resist the opportunity for a good jab! (And as more of a mechanic than body man, I always shake my cans of Wal-Mart primer very well before spraying!) BP
          Ayn Rand:
          • #20
            Bob, you gotta step up to the GOOD spray cans. After you try Krylon, you'll never go back to the cheap paint!
            • #21
              I know that's true, Nate, but figured it would be funnier using Wal-Mart, as much as us CASOs are known for frugality.... BP
              Ayn Rand:
              • #22
                Jim, that's unfair! You said, quote: "It's SO simple, almost unbelievable"... I would never have guessed it. On a Chevy I'd notice it right away, but with limited Stude experience I'd never think of it...[)]
                I'd love to know the diagnostic process that led Lee to that conclusion without seeing it[?]
                Parish, central NY 13131
                • #23
                  It was the backfiring through the carb. I did not guess it because I did not know why he removed the plug wires from the cap instead of the plugs just to do the values.
                  JDP/Maryland
                  JDP Maryland
                  • #24
                    Had this same problem on a '70 Impala I used to own. And you're right - it's so simple you'd never think of it
                    Clark in San Diego
                    '63 F2/Lark Standard
                    www.studebakersandiego.com
                    • #25
                      JP is right, the backfiring through the carb, As Lee said, the engine doesn't give a ----, where the plug wires are, as long as spark goes to #1 when it's supposed to. It just didn't make any sense as all I did was adjust the valves! I dug out my shop manual, motors, and then called Lee AFTER checking everything 2-3 times (or more)
                      I ended up pull ling the left valve cover, and looking at the rotor location when the timing marks were lined up! I just don't understand WHY who ever droppedi nthe dist. just didn't pull it back out and fix it right. I spent less than 10 minutes pulling the valve cover AND dist.
                      Takes all kinds I guess
                      Jim
                      their Memorials!
                      • #26
                        A few years back, I helped a guy rebuild the V8 in his '55. This help was administered via numerous E-mails and phone calls (on his dime, of course).
                        The BIG DAY came and while he had good oil pressure and the thing was cranking great, it would only occassionally sneeze and pop. He ran the battery down a couple of times trying to get it to fire.
                        With each plaintive call to me, we'd run thru the possibilities and check them off - good compression, adequate fuel, etc., etc.. Firing order was of course confirmed as was the rotor pointing to number one when it was supposed to.[}]
                        The one thing I took for granted (and couldn't see from 200 miles away) was that he had the wires in order alright - just in reverse rotation to how the distributor turned![8]
                        I finally enlisted a trusted Stude guy that I knew in his area. The guy started going over the basics, caught and corrected the wires on the cap and with the first start attempt thereafter, the thing fired right up!
                        T'was an amusing phone call I got thereafter. I answered the phone and only heard the distorted grumbling of an engine. My friend was so excited he could hardly speak.
                        1957 President two door
