changing the front pulley ??'s
  • changing the front pulley ??'s
    Hi All,
    I'm adding A/C to my '60 Hawk which has a single pulley. I have a 3 pulley setup off a '61 engine which I want to put on as I also have a P/S setup from the same '61 that I'll add later. To accomplish this, I will have to pull the pulley hub to change to the longer hub/pulley bolts and while that's off I'll install a new seal in the timing cover. Would normal procedure be to replace the rubber cushion pads that go on either side of the vibration damper flywheel?
    Also, if there is anything else I should be aware of for this little project, please let me know.
    Thanks - Mr Mike
    Upon inspection, if the rubber looks good forget about replacing it. Mine was ok. jimmijim
      OK and thanks jimmijim
        Do you have the correct water pump pulley(s)? The AC pulley for the water pump is very hard to find.
        You will need the longer bolts from the '61 Hub for the hub/damper/pulleys. If you have to purchase them...get Grade 8's and use lock washers and BLUE Lock-Tite on them.
        Ray
        Ray
        www.raylinrestoration.com
          quote:Originally posted by Mr Mike
          Hi All,
          Thanks - Mr Mike
          Ya gonna do that without pullin' the timing cover[?][?][?]
          Jerry Forrester
          Douglasville, Georgia
          Be sure to check out my eBay store
          http://stores.ebay.com/CHROME-CHROME-CHROME_ and my EZ33 store http://tinyurl.com/2g2j88
          for your shiny Stude stuff
          More pix of Leo the '55 Pres HT here...http://tinyurl.com/2gj6cu
          Jerry Forrester
          Forrester's Chrome
