how am I gonna fix this? Trunk lock.
  • how am I gonna fix this? Trunk lock.
    Well, I unlocked my deck lid on my 63 lark this morning and promply closed it when I realized what I needed was not in the trunk. I then realized that what I needed was indeed in my trunk, and when I went to open it, the key just spun around in circles in the lock mechanism. It looks like there is no way to open the trunk at this point. I found out that if I remove the rear seat and the cardboard backing, I can get into the trunk that way, but my question is, will I be able to remove the lock mechanism from the inside without opening the trunk? I have not crawled in all the way to take a close look at it yet, but I thought I could pick some brains before I hurt myself trying the wrong thing. (plus, I have an aversion to small enclosed spaces) Any help would be much appreciated. (oh, by the way, thanks to all of you for the help in the past on my previous questions!!)
    1963 Lark Custom, 259 V8, TT, 4 doors, 2 tone paint. Driven often, always noticed. Man I love this car!!
    One of the inherent weaknesses of the 62-3 cars has happened. The chincy pot metal truck lock cam has broken and can no longer trip the latch[V] I believe a trip into the trunk is in store for you!
    1957 President two door
      Rather than removing the lock mechanism just take the 2 screws out of the u shaped latch on the body, much easier and quicker. Ask me how I know
      Frank van Doorn
      1962 GT Hawk 4 speed
      1963 Daytona Conv
      1941 Champion R-2 Rod
      Frank van Doorn
      Omaha, Ne.
      1962 GT Hawk 289 4 speed
        I'd just pull the u-clips that hold the lock cylinder. Once that's out, you can actuate the latch with a finger thru the hole.
        BTW, if anyone with machine skills wants to recreate this part in aluminum with a CNC, I'd be in for one (and I'm sure a bunch other '62/'63 owners would, too). It took me 2 years to locate the NOS one I've got on the car now, and when that one fails I foresee either another long search or carving one out of mahogany!
        Clark in San Diego
        '63 F2/Lark Standard
        www.studebakersandiego.com
          Well, the U-clip can be cantankerous whereas Frank's approach (if I remember right, 'cause I've had to do this in the past) you can do with a 7/16ths socket and a bunch of extensions if you're too big to fit thru to the trunk.
            I agree with the method of unscrewing the lower hook from the body. Its true that you don't even have to crawl into the trunk to get it done. As said above, just use a monster length extension.
            sals54
            sals54
              Thanks for the tips! Sounds like I am gonna have fun getting a new shaft... oh well, its all good!!
                quote:BTW, if anyone with machine skills wants to recreate this part in aluminum with a CNC, I'd be in for one (and I'm sure a bunch other '62/'63 owners would, too). It took me 2 years to locate the NOS one I've got on the car now, and when that one fails I foresee either another long search or carving one out of mahogany!
                I've got a NOS one as well, yet to be installed. If someone would be willing to CNC the part, I'd remove the cam from the lock mechanism and let them borrow it. Any takers?
                Matthew Burnette
                Hazlehurst, GA
                  I'll look-see if I have a used one kickin' about in the shop. It's a possibility.[8)]
                    Unless the CNC part were to be made from steel, it would soon fail, too. Problem is, the section thickness is too small to support the load in less-than-ideal conditions.
                    I repaired one such lock by bending up the crank portion from 1/4" key stock, welding it to a thin steel plate, and bolting that plate to the remainder of the old part via two small tapped holes.
                      Whew!, Thank goodness I've got a Transtar.[}]
                      <h5>Mark
                      '57 Transtar Deluxe
                      Vancouver Island
                      Are you planning to attend the NW Overdrive Tour in Parksville, BC
                      May 23-25, 2009?
                      </h5>
                      Mark Hayden
                      '66 Commander
                      Zone Coordinator
                      Pacific Can-Am Zone
