1950 Champion L/Frt. brake drum
  • 1950 Champion L/Frt. brake drum
    Back again with my left front brake noise problem. It makes a rubbing noise on each revolution as the brakes are applied. These new shoes have less than 1200 miles on them and worked fine for about 800 miles. Things I've done to correct the problem: Turned the drum, reset the shoes and auto adj. plug, adj. brake, checked for rub or uneven wear spots on the shoes and drum, bled all cylinders, reset torque on spindle. The auto adj. works as it should as indicated by the shop manual.
    The car stops straight and true, I just can't handle a noise that should not be there. Sooo, I think I'll just replace the drum. But a left front 1950 Champion drum is not a easy find, I've tried. I expect I'll have to settle for a used assembly, but that's o.k. as long as it's a good one. I need some help on this one guys. I can live with things like a gas gage that doesn't work, but not brake noises.
    Dick
    Mountain Home, Arkansas
    http://livingintheozarks.com/studebaker.htm
    Dick
    Mountain Home, AR
    http://www.livingintheozarks.com/studebaker2.htm
    The only difference between the left and right drum is the lug studs. Left drum has left hand threads and the right drum right hand threads. If you find a right drum just change the lug studs to left hand threads or change the lug nuts to right hand threads.
      What shape are the little steel spring clips that hold the shoes to the backing plates? If they were weak, I could see the shoes maybe twisting to where they didn't contact the drum face squarely. These little spring clips are peculiar to 1950.[:I]
      As Champ says, no real difference between right and left drums save for the stud threads. Studebaker got away from that supposed safety factor after awhile, so you could use a RH drum (with RH thread nuts, of course) and no problems would result.
      Miscreant adrift in
      the BerStuda Triangle!!
        Dick
        Mountain Home, AR
          This may not be the problem but we encountered this with my fathers 47 Starlight Coupe.
          He was having brake noise problems with his right front brake.
          It was especially noticable during turns but then progressively got worse during regular drives.
          Often we would pull to the side of the road, jack up the car remove the wheel and brake drum and inspect for what the cause was.
          To make a long story short the spindle was starting to crack near the kingpin.
          It took dye penetrant to make this visible.
          He got a new spindle and the problem was solved.
          Just another place to check.
            Wow! that's a good one! Dick, if per chance, you NEED a spindle (and I might even have a good used drum - I'd have to measure one to see), I have one or two.
            Miscreant adrift in
              I'll keep that in mind Mr. Biggs. I ordered new retainer clips and a return spring, I'll see what happens there first. Both front spindles are grooved, almost like they were made that way. Anyway, I'll check the spindle out very carefully. Thanks again.
              Dick
              Mountain Home, AR
              Dick
              Mountain Home, AR
