If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You will have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Easiest? Another Studebaker alternator. Shouldn't be too hard to get. Or take your alternator to a good local auto electric shop and have it rebuilt. The brushes and diodes are still available, as are the bearings.
Probably the simplest OTHER alternator to install would be the "basket-style" one used on Chrysler products for many, many years. I think it will bolt up to the Studebaker bracket, maybe with the aid of a few washers, and the electrical connections are the same.
I agree. No need to invent something. I had the one done on my '63 for about $80 here locally. New everything. Solid state regulators are available also that look almost identical to the originals.
Thanks all. Went through my stash of spare parts and found a spare alternator and put it on. Took the car over to my friendly neighborhood stude fixer and had him test the circuit - all is well at this time. I'll have the other rebuilt. Just wanted to have everything working well before the Coleman, Mi., car show on the 14th. Thanks again.
Check out my disc brake adapters to install 1994-2004 Mustang disc brakes on your Studebaker!! http://forum.studebakerdriversclub.c...bracket-update
Can you get a solid state regulator for a generator equipped (Delco) Stude[?]
<h5>Mark
'57 Transtar Deluxe
Vancouver Island </h5>
Mark Hayden '66 Commander Zone Coordinator Pacific Can-Am Zone
Randy Rundle (Fifth Avenue Internet Garage) offers
Solid State Generator Cutout Direct replacement for all 6/12-volt 35-amp and smaller generators that originally had a mechanical, cutout type voltage regulator. No mechanical points to adjust or wear out. No more battery drain. Greatly improves charging system reliability.
Part #02415SSC-$45.00 each
He also offers 6 and 12 volt alternators.
[img=left]http://www.alink.com/personal/tbredehoft/Bothcars4.jpg[/img=left]
Tom Bredehoft
'53 Commander Coupe
(Under Construction) 267 hrs.
'05 Legacy Ltd Wagon
All Indiana built cars
Tom Bredehoft
Excellent! Thanks Tom.
<h5>Mark
'57 Transtar Deluxe
