What Year?????
  • What Year?????
    A easy question. What year did Studebaker go to a 12 Volt neg. ground system???
    It is. For Studebaker, 55s were 6v, 56s were 12v.
    Paul
      For clarification: 55 was 6v positive ground, 56 was 12v negative ground.
        Thanks, I know Ford went in 56 and Chev in I think 55,wasn't sure on Stude.
          Was wondering if anyone makes a conversion kits for a 1950 stude 2r pickup..want to convert to all wheel disc..or will i have to get a chevy front end and rear end to do so...also no title for truck how do i go about getting one becuase there is no vin# with car..restro project so have time but want to get the ball going on this please help..
            Jim Turner makes a disc brake kit for your truck...
            Hope the info helps.
            http://www.turnerbrake.com/truckkits.html
              quote:Originally posted by DEEPNHOCK
              [navy][b]Jim Turner makes a disc brake kit for your truck...
              I don't know if Jim makes disk conversions for the rear of early 2R trucks yet, but if not, late Champ drum rears are a bolt on and give you modern self energizing drum brakes.
              If you are converting to 4 wheel disks, you are probably also updating the engine and trany. If so, you'll probably want a different rear end also.
              Bellingham, WA
                Those 8E Champ brakes will be tough to find tho. Not too many 8E donors around anymore.
                Miscreant adrift in
                the BerStuda Triangle
                  We had a 1955 Chevy truck and it was 6 volt (battery in the floorboard).
                    quote:We had a 1955 Chevy truck and it was 6 volt (battery in the floorboard).
                    It must have been an early (first series) 55. The late 55 Chevy pickups were 12 volt with the battery in the engine compartment. I think all GM and Packard were 12 volt in 55 (maybe Nash)and the rest changed over in 56.
                    Leonard Shepherd
                    http://leonardshepherd.com/
                      Leonard, It was a first series (I had that in my response and then took it out before posting). Despite being a 6 volt system, it had 2 speed electric wipers from the factory.
