4E rear end swap
  • 4E rear end swap
    In the early planning of the Caddy swap in my 59 truck I'll need to research a Chevy wheel bolt pattern rear with a good highway ratio. Someone suggested a Nova, someone else "thought" a Camarao rear would drop right in. Any idea's on year and model to look for in the bone yard ? BTW, it's the 59 inch wheel to wheel wider late truck rear.
    Studebaker On The Net
    http://stude.com
    Studebaker News Group
    Arnold Md.
    64 Daytona HT
    63 R2 4 speed GT Hawk
    63 Avanti R1/AC
    63 Lark 2 dr.
    62 Lark 2 door
    60 Lark convert
    60 Hawk
    59 3E Truck
    56 truck
    55 Starlight
    53 Starlight
    52 Starliner
    51 Commander
    JDP Maryland
    John,
    Unless Dick happens to know off the top of his head, you may do well to toss the question out on the Truck Talk site. The have a search function too, but there have been a number of threads about rear end and gear swaps. While most are concerned with changing the ratio for greater speed, there are also ones about updating axles and adding disc brakes.
    Gary
      The 70 1/2 to 81 Camaro Firebird Nova(and several other GM variants that are less common) are essentiall the same and use the 8 1/2 ring gear, and have a 5 on 4 3/4 wheel lug pattern. They are set up for leaf springs, and about 55-56 inch wide flange to flange(IIRC). Older Camaros, chevelles and Novas, etc. use a similar rear end with an 8.2 ring gear, but parts are less commonplace and don't interchange as well.. The former is what I would recommend--they are very popular for swaps. I you need one that is wider, the full-size GM cars used the same gears in a somewhat wider housing(try wagons) during the late 70s and 80's. Some of them(wagons, police & 98's, electras) used a 5 on 5" bolt pattern. They were all set up for coil springs, but you can torch off the backets and weld spring pads on for leaf springs. Cadillacs are the one I've seen posis in, usually. If the car had overdrive, it probably will have a 3.42 ratio, but most non-od were higher geared. G-series vans used the widest housing of all, with 5 on 5 wheels.
        I have had two 1959 Studebaker pickups with Chevelle rear ends in them. They both worked well and have a good highway ratio. One had a 400 in front of it and the other a 350.
        1959 DeLuxe pickup (restomod)
          Is the 4E a 5x 4 3/4 wheel pattern ?
          http://stude.com
          Arnold Md.
          64 Daytona HT
          63 Avanti R1/AC
          63 Lark 2 dr.
          62 Lark 2 door
          60 Lark convert
          60 Hawk
          59 3E Truck
          56 truck
          55 Starlight
          53 Starlight
          52 Starliner
          51 Commander
          JDP Maryland
            Nope 5 on 5, Chevy truck bolt pattern.
            5E13
            7E7
            8E7
            8E12
            8E28
            4E2
            59 Lark
            etc
              OK, now leaning toward a gear swap in the factory axle.
              http://stude.com
              Arnold Md.
              64 Daytona HT
              63 Avanti R1/AC
              63 Lark 2 dr.
              62 Lark 2 door
              60 Lark convert
              60 Hawk
              59 3E Truck
              56 truck
              55 Starlight
              53 Starlight
              52 Starliner
              51 Commander
              JDP Maryland
                No, they are originally 5X5, but both of my 1959s had/have GM subframes in front so that matches up with the GM rear ends (as far as bolt pattern).
                  Here you go, chev pattern 5 on 4 3/4, numerous ratios, lsd or freewheel, very strong, disc brakes, independant and cheap. What more could you want.
                  [/IMG]http://i77.photobucket.com/albums/j76/sudsy55/smalldiff.jpg
                  http://i77.photobucket.com/albums/j7...lldiffside.jpg
                  http://i77.photobucket.com/albums/j7...lldiffrear.jpg
                  Regards Bob
                  Regards Bob
                    Sounds like your having fun..My question is why a GM rear end with a 4 3/4 or 5 inch bolt pattern. Why not a Ford 9" rear with a 300 plus rear gear. ( I don't know trucks) Ford has a 4 1/2 bolt pattern the same as Stude cars and the Avanti. You can always have a machine shop drill out and plug the the hub bolt pattern that you need. The Ford 9" is the strong "boy" hot rodders use and can be adapted to any vehicle. I'm running a ford 8" in a 40 ford and a ford 8.8 in a 28 Buick, both with GM 350's as the power plant. Early ford rear ends, are tough and can handle a Caddy power plant.
                    Ford has a 4 1/2 of 5" bolt pattern for the most part..................with both the 8" and 9" rear ends. Should cost at a swap meet $100 to $ 250 depending on the ratio.
                      John,
                      I ran across this site some time ago and bookmarked it because it gave such good info on rear ennds and widths.
                      Hope it is some help.
                      http://50chevy.freeservers.com/Suspension_Widths.html
                      [img=left]http://i82.photobucket.com/albums/j259/stude53/studesmall2.jpg[/img=left]Bob Feaganes (stude53)
                      53 Starliner Hardtop
                      Newton Grove, NC
