Voltage Regulator for Avanti
  • Voltage Regulator for Avanti
    Anybody have an off the shelf # for a 64 Avanti voltage regulator? A solid state unit would be fine.
    On Bob Johnstone's web site there is the part number for the solid state module to install under your old can.
    JDP/Maryland
    JDP Maryland
      Bob Langer
      Glenshaw,PA
      Bob Langer
      Glenshaw,PA
        quote:On Bob Johnstone's web site there is the part number for the solid state module to install under your old can.
        Mr. Bove:
        Contrary to JDP's reference, it would probably be better to install the solid state device under the old Prestolite cover.
        Have you found the Studebaker chambered exhaust article yet?
        Best regards as always,
        Geno Robino
        1963 Studebaker Avanti: C4 Corvette narrowed front/rear suspension, C5 13" calipers/rotors adapted to C4, Viper differential with Intrax 3.54 ratio (the snake has been charmed!), coil overs, stainless tubular frame, stainless chambered side exhaust.
        Here are two links for some pictures and information.
        Slide Show
        Magazine Article
        sigpic 1963 Studebaker Avanti: LS1 motor and T-56 transmission have been moved rearward, set up as a two seat coupe with independent rear suspension. Complex solutions for nonexistant problems.
