FYI, here's the specification chart for speedi-sleeve repair kits.
the most common studebaker applications are for crankshaft hub and pinion and driveshaft yokes. Any machined shaft to seal surface can be repaired with these, so if you have a application and don't know the part # this document will help you out.
Russ
http://www2.vsm.skf.com/Files/Brochu...PDF/457027.pdf
57 SH (project)
60 Lark VIII 2dr sd (driver)
Russ
57 SH (project)
