can a 259 or a 289 crank be installed in a 224 block.
224 motor
Great piece of info, Dwain. I've owned a 224" for twenty-five years and didn't know the cam was advanced. Is it the 224" crank gear, cam gear or the location of the keyway in the crankshaft or in the damper hub different from a 259" or 289"?
thnx, jack vines
PackardV8PackardV8
Yes, every year or two someone discovers the cam specs for the 224's and thinks they have discovered a stock, 'secret' hot cam. But when you look at part numbers, everything except the crank is the same as other V8s.
As I'm sure you know Jack, that's an old trick used to give a small displacement engine more low end torque. Offset keys for cam gears are still sold, and I sometimes wonder why I never hear of anyone using them in a Stude.
Dwain G.
AL SORAN RACING
Hi, Dwain,
Just to get my mind right on this, exactly what is different which makes the pointer on the 224" read differently on the front balance damper when the damper is installed on a 259"/289"? Is the keyway on a 224" crank cut at a different location?
thnx, jack vines
PackardV8PackardV8
Yes it is. That's the only piece that's different. Camshaft, timing gears, and keys are the same as other V8s. As far as I know, all 224 vibration dampers have part no. 536563 stamped right after the IN. OP. 1
Dwain G.
AL SORAN RACING
