Hi, I am working on a 57 silver hawk. I have to put the washers and spring clips on the bottom of the drivers side window. There is very little room and it also has a spring on the post that the washer and spring clip go on. I can't seem to find the trick to doing it, PLEEEEEASE help.
Thanks,
Wade
Thanks,
Wade
Of course, from the side means you have to hold that washer/channel/spring trio well compressed with one hand while working the clip on with the other. Using the direct approach, you can use BOTH your index fingers to pop the clip/washer duo onto the post while pushing the base of said post with both thumbs. Sorta like pinching the whole mess together until you feel the clip snap into the groove!
