Anybody know of a way to keep the mechanical linkage on the kick down of a 3 speed flightomatic and incorporate it into a Lokar cable throttle linkage attached to an edlebrock carb? Any answers, opinions or questions would be appreciated.
Transmiision kick down
Try the Lokar kickdown kit: ( For Ford)
http://www.lokar.com/product-descrip...ch-kd-kits.htm
JDP/Maryland
JDP Maryland
On any FMX the kickdown is just that,its only purpose. On the Flightomatic the rod does two operations kickdown AND throttle pressure , it raises transmission mainline pressure in response to accelerator position. If mainline isn't boosted you will get early shifts doggie acceleration and soon a burnt up transmission. Same thing happens to 700R4,s and AOD,s if throttle pressure is set too low or on AOD,s failure of the upper linkage grommit{cooked by engine heat}. On Fmx prior to late 1961 the lever did the same as Flightomatics. Most or all of the parts are available why mess with the Lokar stuff? Lou Cote "Waiting for the sun" [8D]
With a transmission pressure gauge hooked up to the line pressure port on the trans. With engine and trans warmed up place selecter in D operate engine at 1000 RPM with the rear wheels held stationary by the foot brake . Adjust the bellcrank to throttle valve lever rod to obtain 80 to 85 psi, replace 1/8 pipe plug and test drive. Lou Cote [8D] Found the sun today
Well before I went any further ,obtaining a shop manual would be a great help. Pressure tap plugs could be found in two locations, on my 62 Hawk it is on the left side of the case just in front of the manual/TV valve levers. On some of the later flightomatics it is located at the back of the case just above the oil pan. To be a little clearer you're looking for a 7/16 pipe plug. For shop manuals either Studebaker International or Faxon Literature {on ebay} should have what you need. Lou Cote
