1951 CHAMP-1960 LARK
  • 1951 CHAMP-1960 LARK
    DOES ANYONE KNOW IF A 1960 6CYL WILL FIT IN A 1951 CHAMP WITHOUT TOO MUCH TROBLE? ANY HELP WILL BE GREATLY APPRECIATED. THANX! AL
    Yes, it will. The only thing you might have to change is the crankshaft bolts at the rear. This, if you're gonna change from manual shift to automatic or vise-versa.
      I PLAN ON LEAVING IT STICK, BUT ADDING OVERDRIVE. THANX!
        Will a 12 volt starter turn a six volt system?
        Ted
          If the '51 is still 6 volt, wouldn't the flywheel and starter from the '51 have to be reused?
            Well, he didn't ask about the electrical system.[}] I doubt a 12volt starter would work adequately on 6 volts! AND, as Blue 54 Champion points out, there ARE differences between the tooth count of the starter drives and ring gears 12V vs 6V
              I hope you have a complete Lark engine including the correct bell housing. Some 30 years ago I bought a 1959-60 Lark service kit from SASCO and tried to put it into my 47 M-series pickup. I ran into problems because the back of the blocks were not the same. I still have the engine, but never tracked down the parts to put it in the M. The 51 car set-up might be a little friendlier though. Just my 2 cents.
              !952 Champion Starlight since October,1971. !962 Daytona
              since May, 2007.
                Use the 1950's starter and flywheel, the 6 volt starter will work fine on 12 volts.
                JDP/Maryland
                63 GT R2
                63 Avanti R1
                63 Daytona convert
                63 Lark 2 door
                62 Lark 2 door
                60 Lark HT-60Hawk
                59 3E truck
                58 Starlight
                52 & 53 Starliner
                51 Commander
                JDP Maryland
