53 cloverleaf 232
  • 53 cloverleaf 232
    I think I understand that the cloverleaf is a replacement engine. Is the 232 a H.D. replacement just as the 259 and 289? What should I see different inside? When I removed one of the valve covers it had a metal tag in the center of the rocker arm shaft with the valve settings stamped on it. Is ths standard on a 232 engine? I have never seen this on a 259 or 289.
    Tex in Alabama
    53 C coupe
    Tex E. Grier
    Because of the problems with soft camshafts on early '51 232's, I imagine they needed to remind installers of the new setting and that this was an "improved" 232, anyway I have seen new crate replacement 232's with the tin plate for whatever reason.
    If the part number on a tag on this engine starts with a "6" and not a "5" it IS a Truck engine, most likely H.D. with the H.D. Valves and Rod. & Main Brgs. they did not have the Aluminum Cam Gear on 232's.
    Studebakers Northwest
    Ferndale, WA
