Late pan &dipstick on early FOM. Yes/No?
  • Late pan &dipstick on early FOM. Yes/No?
    Will a later pan, with the engine compartment dip stick work on an early FOM with dip stick on top/ under the floor pan? The gasket matches, the depth measures the same from the outside anyway, and a mock up indicates the dip stick tube clears. I hope to remove the existing dipstick and put a freeze plug in its place. I am looking for a confirmation prior to diving in. Has anyone out there done this?
    Saturday marks the date of the first gear start with a $5 spring experiment, it may be folly[)] but I am going to give it a go. I must go in anyway in to fix the massive leak from the shift lever seal.
    I appreciate all your help, past and present.
    Ross.
    Riverside, Ca.
    1957 Provincial X2
    1958 Transtar
    1963 Lark. F.S.
    Ross.
    Riverside, Ca.
    1957 Provincial X2
    1958 Transtar
    The dipstick tube won't clear the exhaust pipe, at least on a C-K body. I am guessing that this is for your Provincial; not sure if that's an issue there or not.
    (learnin' stuff the hard way every day)
      When Dad and Mike installed the h/d auto. trans in my Parkview, that's exactly what they did!!! I don't beleive there were any problems. Sorry, I can't say for sure, as I wasn't there for the actual installation. I have seen it after the fact~ and it's in there~ They got it to work somehow!!!
      StudeDave [8D]
      V/P San Diego County SDC
      San Diego, Ca
      '54 Commander 4dr 'Ruby'
      '57 Commander 2dr 'Baby'
      '57 Champion 2dr 'Jewel'
      '58 Packard sedan 'Cleo'
      '65 Cruiser 'Sweet Pea'
      StudeDave '57
      US Navy (retired)
      SDC Member since 1985
      past President
      Whatcom County Chapter SDC
      San Diego Chapter SDC
      past Vice President
      North Florida Chapter SDC
        Thanks all.
        Yes, it is the Provincial. It has locally installed dual exhaust. I will have to double check prior to bolting it down tight.
        Ross.
        Riverside, Ca.
        1957 Provincial X2
        1958 Transtar
        1963 Lark. F.S.
        Ross.
        Riverside, Ca.
        1957 Provincial X2
        1958 Transtar
          Ross; I think because the '57 Sedans/Wagons are basically Lark type bodies, I used the Lark filler tube not Hawk, they are different and it went right in Dave's Parkview with a late model '61-'66 oil pan. We used a '57 GH Tranny with the cooling lines & added a oil cooler radiator as well. After all, it IS a Stationwagon!
          Rich.
          quote:Originally posted by Rosstude
          Thanks all.
          Ross.
          Studebakers Northwest
          Ferndale, WA
            See, I knew Dad would have the answer~ he almost always does!!! [:0] [^]
            StudeDave [8D]
            San Diego, Ca
            StudeDave '57
            US Navy (retired)
            past President
            past Vice President
