I would like to get the spec's for 1952 169CU 6cyl Engine. Head Nut pattern and Torgue.
Spec. 1952 169 CU 6 cyl Engines
This is the info for a '50 6 cyl 169 ci flathead, Champion.
From the reference point that you are facing the block on the manifold side, number the bolts starting on the row closest to you and left to right with these numbers -- 19, 18, 17, 3, 2, 11, 12, 13. The middle row (next row away from manifold), left to right, -- 9, 6, 5, 1, 7, 8, 10. The row furthest from you, left to right, -- 22, 21, 20, 4, 14, 15, 16. Torque limit for the Champion is 46-50 ft. lbs. More info after the Commander numbers.
For the Commander, from the manifold side, left to right, --21, 20, 19, 18, 3, 2, 11, 12, 13, 14. The center row, left to right, -- 9, 6, 5, 1, 7, 8, 10. The row furthest from the manifold, left to right, -- 24, 23, 22, 4, 15, 16, 17. Torque limit for the Commander is 80-85 ft. lbs.
Common info for both engines: re-torque a second time before starting engine. After warming up engine to 170 degrees F. retorque again.
'50 Champion, 1 family owner
You can find them on internet auctions or buy a new copy from many Stude vendors for $30.Brad Johnson,
'56 Sky Hawk in process
