FRANZ BiPass Oil Filters
  • FRANZ BiPass Oil Filters
    Hi
    I have had a 59 VI Lark that I saved from melting into the ground, for about a year and a half now and there was no oil filter on it at all. Apparently that was an option in 59. Anyway, my Dad (a long time car guy and retired mechanic) had an NOS Franz Oil Filter (toilet paper) kit, brand new in the box he'd had since the 60s, that he gave me. I installed it on the car and it works fine. However it has begun leaking a bit around the bottom of of the can. A friend of mine saw a post on this forum a while back about putting a restrictor in the line on these filters, to slow down the full pressure from the engine to the filter and eliminating the leaking. I cannot find that post, so I'm putting up a new one in hopes someone with experience with Franz filters has some information on this or in general about these filters.
    This car has been a real joy and I'm hoping to make it more of a daily driver, than a trailer queen. [:X]
    Thanks,
    Deby
    Restrictor, or no restrictor....
    Your filter should not leak with 60+ psi of oil pressure inside of it.
    Find the source of your leak and fix it.
    quote:Originally posted by Studebiker59
    Hi
    Thanks,
    Deby
      Exactly what Jeff said, you don't fool with the flow on a bi-pass oil filter, Frantz has the correct SAE required size hole already drilled in the inlet fitting hole in the center port of the base. You do not change those, all it would do is reduce the volume of oil reducing the efficiency of the filter. All you need is a new base gasket. They do a very good job when changed every 1000 to 2000 Miles Max, they do not require oil changes due to the detergents being replaced at each filter change by replacing the missing quart absorbed in the tissue.
      Lab tests have proven the cleanliness of the oil.
      There is a guy in Texas that still has the base gaskets, parts, new filters and adapter rings to convert the center shaft to the new larger size core of modern Toilet paper available today, it must fit tightly on the center post! I found some Costco Kirkland brand tissue that has the old style small core and fits if you can find it.
      Found this with a Google search for Frantz. This may be the guy I bought from, I don't know but I see he has the #218 base gasket $2.00 ea. for type "C" that's the square gasket, not "O" ring for the type with the clamp at the base of the canister.
      http://www.wefilterit.com/orders/200/index.htm
        Hi
        Thanks,
        Deby
        OK, for what it's worth.........
        From the Frantz website FAQs at: http://vs01.tvsecure.com/cgi-bin/vs0...q/smartfaq.cgi
        I changed my Frantz Oil Cleaner/Filter from my old car to my new one and I now have a leak problem around the base clamp. What is wrong?
        If you have moved your Frantz from an older vehicle to a newer one and have a leak problem, you may need a 1/16" Orifice Restrictor to help control the pressure of oil flow into the unit now. This can happen with vehicles that have a higher than normal oil pressure pump. Leaking is caused when oil is forced into the Frantz Oil Cleaner/Filter faster than it can exit.
        However, most Champ six engines I have had experience with don't seem to have "higher than normal oil pressure".....
        Paul
        Winston-Salem, NC
        Paul
        Winston-Salem, NC
          Here's the Franz Web Page.
          Steve
          53 Commander Hardtop
          55 Commander Conestoga
          60 Lark Convertible
          62 Champ 7E7
          49 2R15 Stakebed
          Steve
          Never drive faster than your Guardian Angel can fly!
          53 Commander Hardtop, A/T, P/S
          60 Lark Regal Convertible, A/T
          59 Lark 4 Door Parts Car
          62 Champ 7E7, A/T
          49 2R15 Stakebed
            I've ran these filter before, keep your o-rings fresh and they shouldn't leak.
            Hi
            Thanks,
            Deby
            57 SH (project)
            60 Lark VIII 2dr sd (driver)
            53 2R6 289 5SpdOD (driver)
            57 SH (project)
              Out of curiosity, has anyone done oil sampling on an engine using this filter set up? I wonder about the chemicals used in the paper making process and their
              effects in motor oil.
              64 Champ long bed V8
              53 Hudson Super Wasp Coupe
                Many, many samples were taken with amazingly good results in the 50's, 60's and 70's when these were popular back in the days when the installation instructions only needed about six types of installations instead of thousands on today's cars, and there was available space and excess to the engine to install one.
                There were tripple stackers for larger engines, marine and Diesel, grinding machines etc. and they were approved for Aircraft use after the Aeroquip clamp replaced the spring clamp.
                We used two ply Chiffon white then, no longer available in tightly wound, non-perfume, non-colored, non-quilted, non-fluffy etc. so we use Scott 1000 single ply.
                I believe they fell out of favor for exactly those two reasons. The Sky Corp. in Stockton, Calif. then moved on to manufacturing more profitable items. Hmmm...now where have you heard THAT story before?
                quote:Originally posted by Kdancy
                Out of curiosity, has anyone done oil sampling on an engine using this filter set up? I wonder about the chemicals used in the paper making process and their effects in motor oil.
                  There's no way in 4377 I'm hooking up a roll of toilet paper to my car unless it's in the roadside emergency kit...
