Replacing rear seal
  • Rear Axle: Replacing rear seal
    I hope to hit this with my air impact wrench tomorrow to get to the leaky seal. Once the nut is off, you suppose I'll need a puller? I'm more concerned about replacing it, once the seal is fixed. I did something similar to an old Ranger and had to mind over-tightening so as not to scrunch the bearings within. Same with the 44?
    I have removed the trunion by tapping, not pounding, with a soft hammer - plastic, nylon, lead, dead blow.
    60V-L6 - 60 Lark convertible
      Worked great, thanks, Roy!
        Any time, Tom. You are welcome.
          But normally a puller is required. Impact to remove nut. I have a Studebaker pinion seal remover which is GREAT! Be careful installing new seal so you do not damage it. I also have the special tool for that job but one could be made and I have used a socket in the past.
            The crush ring is used in some designs to set bearing preload. Shouldn't be reused and must be tightened to a specific value. Our Spicers do not use that design.
            So.....if I'm 'pre-approved' why do you want me to fill out an application?
