Changing the clutch on my 58 Hawk6.someone messed up previous install flywheel is suspect.Spare flywheel is drilled for 8 1/2 HD? Clutch Original was 8 in Have pressure plates for both can I drill and tap to install smaller clutch?or can I change over to the HD clutch? Will bell housing and linkages interchange?Thanks
Clutch
Originally posted by scoutergord View PostChanging the clutch on my 58 Hawk6.someone messed up previous install flywheel is suspect.Spare flywheel is drilled for 8 1/2 HD? Clutch Original was 8 in Have pressure plates for both can I drill and tap to install smaller clutch?or can I change over to the HD clutch? Will bell housing and linkages interchange?Thanks
Originally posted by Jeffry Cassel View Postnever seen a 58 Hawk 6 cyl. Is it an export? rare bird.
On '59 6 Cyl Hawks and maybe the others, the Wheelhouse MOULDINGS were left off.StudeRich
When I bought my '54 Champion in 1996 it needed the clutch replaced. Original equipment was the 8 inch clutch, but the aftermarket one I put in (Borg Warner rebuilt) was 8-1/2. B-W specified in their catalog at the time to use the 8-1/2. It fit and worked fine with no modifications to the flywheel or anything else. Not sure if this pertains to your '58, but just thought I'd mention it.
EDIT: I just noticed that your original post is from August, 2019 so hopefully you resolved this by now!
