Greetings. I need to attach a pickup bed to a 1949 2r5. It didn't come with a bed from the factory. The manual refers to a "clamp bolt". I see mounting holes on the rear, but not on the front. any help would be appreciated.
Attatch pickup bed to frame 1949 2r5
Tags: None
The Studebaker 2R Parts Catalog will picture the parts required to install the bed.
The picture numbers relate to the actual Part Numbers of the Parts and Quantities you need for your Year and Model.
Yes, Clamp Bolts and Nuts.StudeRich
There's a simple bracket that's bolted on to the forward section bed on each side with only 1 bolt (keep it loose while lowering the bed and pointed towards the center). once the bed is lowered completely into place, put the rearmost bolts into the back of the bed to bolt only the rear section of the bed down.
Then swing the brackets under the top rail of the frame and tighten. Easy Peasy.
Originally posted by StudeRich View PostThe Studebaker 2R Parts Catalog will picture the parts required to install the bed.
Here is a photo of the clamp on my '63 Champ. It's the same as your '49. Hope this helps.
